Author Topic: Count Items in a list  (Read 7903 times)
Marc'Antonio Alessi
  • Marco
Re: Count Items in a list
« Reply #15 on: January 24, 2013, 10:36:36 AM »
Very deep but slower  :-D
If I were aiming for raw performance, I would not be using recursion...  :roll:
It is a very new approach  :kewl:
 :-D
« Reply #16 on: January 24, 2013, 10:38:50 AM »
 :-D
I guess you're new here  :lol:
« Reply #17 on: January 24, 2013, 10:42:39 AM »
 :-D
What was the first clue?
Perhaps the post count?
regardless, recursion does work and is elegant and useful in some cases ... but you knew that already ;-)
Marc'Antonio Alessi
  • Marco
« Reply #19 on: January 24, 2013, 10:57:37 AM »
Yes about recursion.
My 2 cents: append IS very slow:
(append
  nl
  (list item
      (- (length l) (length (setq l (vl-remove item l))))
My apologies for my english.  :-)
« Reply #20 on: January 24, 2013, 02:08:17 PM »
I think you can shave a little more off your function Lee (forgive me if I'm wrong; I have a hard time with lisp now).
Quick once through look.
  1. (defun _count ( l / c x )
  2.   (cond
  3.     ((setq x (car l)
  4.            l (vl-remove x (cdr l)))
  5.      (cons (cons x (- (length l) (length l))) (_count l))
  6.      )
  7.     )
  8.   )
« Reply #21 on: January 24, 2013, 02:13:58 PM »
  2.   (cond
  3.     ((setq x (car l)
  6.      )
  7.     )
  8.   )
Not quite, since (- (length l) (length l)) will always return zero, and you will also miss the last item of the list; but thank you for your interest Se7en, I appreciate your suggestion.
« Reply #22 on: January 24, 2013, 02:16:30 PM »
The [much faster] iterative version might be:
  1. (defun _count ( l / c l r x )
  2.     (while l
  3.         (setq x (car l)
  4.               c (length l)
  5.               l (vl-remove x (cdr l))
  6.               r (cons (cons x (- c (length l))) r)
  7.         )
  8.     )
  9.     (reverse r)
  10. )
« Reply #23 on: January 24, 2013, 02:36:28 PM »
Not quite ...
*nod* Well, it was worth a shot (I'm surprised I got that far ;] ).
David Bethel
« Reply #24 on: January 24, 2013, 03:16:46 PM »
Maybe:
  1. (defun item_cnt (data / cl q)
  2.   (foreach a data
  3.     (setq cl (if (setq q (cadr (assoc a cl)))
  4.                  (subst (list a (1+ q)) (assoc a cl) cl)
  5.                  (cons (list a 1) cl))))
  6.  cl)
  7.
-David
« Last Edit: January 25, 2013, 07:23:54 AM by David Bethel »
R12 Dos - A2K
Q1241274614
« Reply #25 on: January 24, 2013, 09:05:33 PM »
;;;result
;;;(JB2X23X40X100X20X8 (a6 a17))
;;;(JB2X23X50X100X20X8 (a12 a5))
;;;(JB2X26X50X120X40X10 (a9 a15 a18))
;;;(JB1X30X60X150X40X16 (a19 a16 a11 a4))
;;;(JB2X30X60X150X40X16 (a7 a10 a14 a20))
;;;(JB1X26X50X120X40X10 (a13 a8 a2))
;;;(JB3X40X60X155X40X16 (a21))
;;;(JB1X22X40X100X20X8 (a3 a1))
(defun c:test( / )
(setq aa
(list
(list "JB1X22X40X100X20X8"   "a1")
(list"JB1X26X50X120X40X10"   "a2")
(list"JB1X22X40X100X20X8"    "a3")
(list"JB1X30X60X150X40X16"   "a4")
(list"JB2X23X50X100X20X8"    "a5")
(list"JB2X23X40X100X20X8"    "a6")
(list"JB2X30X60X150X40X16"   "a7")
(list"JB1X26X50X120X40X10"   "a8")
(list"JB2X26X50X120X40X10"   "a9")
(list"JB2X30X60X150X40X16"   "a10")
(list"JB1X30X60X150X40X16"   "a11")
(list"JB2X23X50X100X20X8"    "a12")
(list"JB1X26X50X120X40X10"   "a13")
(list"JB2X30X60X150X40X16"   "a14")
(list"JB2X26X50X120X40X10"   "a15")
(list"JB1X30X60X150X40X16"   "a16")
(list"JB2X23X40X100X20X8"    "a17")
(list"JB2X26X50X120X40X10"   "a18")
(list"JB1X30X60X150X40X16"   "a19")
(list"JB2X30X60X150X40X16"  "a20")
(list"JB3X40X60X155X40X16"  "a21")
(setq b (item_sort aa))
(princ b)
(defun item_sort ( l / c l r x e  aa ll)
              (while l  (setq  x (caar l)
                e (cons (cadar l) e)
                l (cdr l)
         (foreach y l
               (if  (= (car y) x)
               (setq e (cons (cadr y) e))
               (setq ll (cons y ll))
          (setq aa (cons (list x e) aa) l ll  e nil  ll nil)
  aa
Maybe I didn't express clearly.I hope this result.Can optimize a (item_sort)?
pBe
« Reply #26 on: January 24, 2013, 10:03:04 PM »
Really now Q1241274614, you change your requirement from this:
(list "JB1X22X40X100X20X8" a1);<--- note second element not a string, hence my Q about being a variable
(list"JB1X22X40X100X20X8"a3)
Result
("JB1X22X40X100X20X8" 2 (a1 a3));<--- note the second element as quantity of found match
Now to this:
(list "JB1X22X40X100X20X8" "a1");<--- both elements as string
(list "JB1X22X40X100X20X8" "a13")
Result
("JB1X22X40X100X20X8" ("a3" "a1"));<-- quantity, gone, not there, not included.
Please make up you mind Q1241274614  ;D
(defun countvar  (l / a b c d )
      (while (setq a (Car l))
            (while (setq b (assoc (Car a) l))
                  (setq c   (cons (cadr b) c)
                        l (vl-remove b l)))
            (setq d (cons (list (Car a)  c) d)
                  c nil))
      d
Marc'Antonio Alessi
  • Marco
« Reply #27 on: January 25, 2013, 03:27:54 PM »
  1. (defun _count ( l / c l r x ) ...
  2.
Yes it is very similar but is faster on long list:
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (COUNT2 ALIST)......1966 / 1.03 <fastest>
    (_COUNT3 ALIST).....2028 / 1 <slowest>
Elapsed milliseconds / relative speed for 1 iteration(s):
    (_COUNT3 ALIST).....2996 / 1.26 <fastest>
    (COUNT2 ALIST)......3776 / 1 <slowest>
« Reply #28 on: December 04, 2016, 01:56:11 PM »
Necro-thread resurrection ...
Had to write a "find all positions of x in list" type function today and realized it could be used to "count items in a list".
Not saying it's the fastest (haven't benched it) but it's a different spin which is always good for algorithm fodder ...
(defun _Positions ( x lst / p )
    ;;  find all the n positions of x in lst
    ;;  (_Positions 1 '(0 0 1 0 0 1)) >> (2 5)
    (if (setq p (vl-position x lst))
        (   (lambda ( lst result )
                (while (setq p (vl-position x lst))
                    (setq
                        result (cons (+ 1 p (car result)) result)
                        lst    (cdr (member x lst))
                (reverse result)
            (list p)
And:
(defun _Tally ( x lst )
    ;;  count all the occurances of x in lst
    ;;  (_Tally 1 '(0 0 1 0 0 1)) >> 2
    (length (_Positions x lst))
For what it's worth, cheers.
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
Marc'Antonio Alessi
  • Marco
« Reply #29 on: December 05, 2016, 08:47:04 AM »
New test:
  (setq aList nil Countr 0)
  (repeat 10000 (setq aList (cons (setq Countr (1+ Countr)) aList)));100000
  (repeat 4 (setq Alist (append Alist Alist))) ;5
  (princ "\nLength   : ") (princ (length aList))
  (princ "    Positions: ") (princ (length (ALE_PositionS 1   Alist))) (princ "\n ") (princ)
(Benchmark '(
(MP_Positions 1   Alist)
(SK_index 1   Alist)
(SK_index 1   Alist)
Length   : 160000    Positions: 16
Elapsed milliseconds / relative speed for 512 iteration(s):
    (SK_INDEX 1 ALIST).........1531 / 1.01 <fastest>
    (MP_POSITIONS 1 ALIST).....1546 / 1
    (SK_INDEX 1 ALIST).........1547 / 1
    (MP_POSITIONS 1 ALIST).....1547 / 1 <slowest>
    (MP_POSITIONS 1 ALIST).....1547 / 1 <fastest>
    (SK_INDEX 1 ALIST).........1547 / 1 <slowest>
; Stefan
(defun SK_index (n l / i j r)
  (setq j -1)
  (while  (setq i (vl-position n l))
    (setq r (cons (setq j (+ 1 i j)) r))
    (setq l (cdr (member n l)))
  (reverse r)
