Author Topic: Can't reenter Lips. error with getstring  (Read 5133 times)
« on: January 17, 2013, 04:33:01 PM »
I did not see any repercussions for this error with my lisp that I just wrote, but was wondering if anyone else has seen this?  Seems to happen every time.
Command: (getstring)
Can't reenter LISP.
BlackBox
Re: Can't reenter Lips. error with getstring
« Reply #1 on: January 17, 2013, 05:05:40 PM »
Not sure I fully understand what you mean, Tim... So, FWIW -
  1. (
  2.
  3. Can't reenter LISP.
  4. "("
  5.
  6. (this is a test)
  7.
  8. Can't reenter LISP.
  9. "(this is a test)"
  10.
BlackBox
« Reply #2 on: January 17, 2013, 05:07:54 PM »
I haven't tested any .NET code myself, but perhaps this is an issue where one is attempting to type LISP within Editor.GetString() ?  :? *not sure*
« Reply #3 on: January 17, 2013, 07:01:23 PM »
AutoCAD 2013:
Can't reenter LISP.
Command: (getstring t)
« Reply #4 on: January 17, 2013, 11:29:07 PM »
The issue was when entering an open parenthesis to 'getstring', the error "Can't reenter Lisp." would show up, but not stop the Lisp routine running.  I was just wondering if anyone has ever seen this issue, and if has caused some errors in the long run?
That solution worked for me in '12 also Lee.  Thanks for that.  Never crossed my mind, in my rush to code my simple routine that I needed.
« Reply #5 on: January 18, 2013, 05:10:31 AM »
No worries Tim; I'm surprised I've never noticed/encountered this result before  :|
« Reply #6 on: January 18, 2013, 06:26:51 AM »
+1 for the thread title.
irneb
« Reply #7 on: January 18, 2013, 06:51:12 AM »
Wow! Does seem irritating doesn't it? I also can't remember this happening. Must be some new "adesk-derived-feature"  :ugly:
tedg
« Reply #8 on: January 18, 2013, 12:02:06 PM »
+1 more (LOL)
(defun c: grammercheck ()
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
« Reply #9 on: January 18, 2013, 12:06:23 PM »
tedg
« Reply #10 on: February 05, 2013, 12:14:06 PM »
+1 more (LOL)
:lmao:
Thanks for pointing that out Lee, I would like to say that I did that on purpose but...  :-[
David Bethel
« Reply #11 on: February 05, 2013, 12:17:40 PM »
What is TEXTEVAL sysvar set to?  -David
R12 Dos - A2K
Matt__W
  • I like my water diluted.
« Reply #12 on: February 05, 2013, 12:56:11 PM »
I thought this was a spinoff of the Snapchat thread.   ^-^
Autodesk Expert Elite
« Reply #13 on: February 05, 2013, 01:06:05 PM »
Good suggestion David, but after a quick test on my system it seems that the TEXTEVAL System Variable unfortunately has no effect on this behaviour of the getstring function. :-(
David Bethel
« Reply #14 on: February 05, 2013, 01:24:42 PM »
Looks like this is the case all the way to alt least R12 DOS. From the customization guide:
The user cannot enter another AutoLISP expression as the response a getstring request.
-David
R12 Dos - A2K
