It was colored dream?
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (TEST1-EVGENIY 10 LST)........1217 / 2.91 <fastest> (NEAREST41-VOVKA 10 LST)......1232 / 2.87 (NEAREST133-VOVKA 10 LST).....1280 / 2.77 (CLOSEST-LEEMAC 10 LST).......1341 / 2.64 (WIZ-NEAR2 10 LST)............1373 / 2.58 (WIZ-NEAR 10 LST).............1435 / 2.47 (CLOSEST2-WHDJR 10 LST).......1451 / 2.44 (NEAREST-CAB 10 LST)..........1513 / 2.34 (TEST-EVGENIY 10 LST).........1841 / 1.92 (NEAREST2-CAB 10 LST).........3541 / 1.00 <slowest>
Lee, we both will be happier if you benchmark the above with 100 instead of 10
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST133-VOVKA 100 LST).....1248 / 2.75 <fastest> (NEAREST41-VOVKA 100 LST)......1264 / 2.72 (CLOSEST-LEEMAC 100 LST).......1342 / 2.56 (WIZ-NEAR2 100 LST)............1342 / 2.56 (CLOSEST2-WHDJR 100 LST).......1404 / 2.45 (TEST1-EVGENIY 100 LST)........1451 / 2.37 (WIZ-NEAR 100 LST).............1466 / 2.34 (NEAREST-CAB 100 LST)..........1514 / 2.27 (TEST-EVGENIY 100 LST).........1747 / 1.97 (NEAREST2-CAB 100 LST).........3433 / 1.00 <slowest>
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST41 100 LST)..........1656 / 1.19 <fastest> (CLOSEST-LEEMAC 100 LST).....1734 / 1.14 (NEAREST133 100 LST).........1750 / 1.13 (WIZ-NEAR2 100 LST)..........1812 / 1.09 (TEST1 100 LST)..............1969 / 1.00 <slowest>
>VovKa, Lee MacShow the arguments with which you have received your results.I have several options, which in various cases faster your.
(defun test3 (n l / a b) (if (vl-position n l) n (cond ((not (setq l (vl-sort (cons n l) (function <)) a (cadr (member n l)) ) ;_ setq ) ;_ not (cadr (member n (reverse l))) ) ((not (setq b (cadr (member n (reverse l)))))a) ((if(< (abs (- n a)) (abs (- n b))) a b)) ) ;_ cond ) ;_ if)
(setq l '(45 23 63 5 8 56 74 32 96 144 95) n 100)(BenchMark '((nearest41 n l)(Closest-LEEMAC n l)(test3 n l)))Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s): (TEST3 N L)..............1500 / 1.22 <fastest> (NEAREST41 N L)..........1531 / 1.19 (CLOSEST-LEEMAC N L).....1829 / 1 <slowest> _$Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s): (TEST3 N L)..............1532 / 1.2 <fastest> (NEAREST41 N L)..........1547 / 1.19 (CLOSEST-LEEMAC N L).....1844 / 1 <slowest> _$ Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s): (TEST3 N L)..............1515 / 1.21 <fastest> (NEAREST41 N L)..........1531 / 1.19 (CLOSEST-LEEMAC N L).....1829 / 1 <slowest> _$
(defun wiz-near3 (n lst / a d e) (cond ((vl-position n lst) n) ((setq lst (vl-sort (cons n lst) (function >)) lst (cons -1e6 (reverse (cons 1e6 lst))) a (vl-position n lst) ) (if (< (abs (- (setq d (nth (1+ a) lst)) n)) (abs (- (setq e (nth (1- a) lst)) n)) ) d e ) ) ))
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (WIZ-NEAR3 100 LST)...........1201 / 1.12 <fastest> (NEAREST41-VOVKA 100 LST).....1216 / 1.10 (TEST3-EVGENIY 100 LST).......1280 / 1.05 (CLOSEST-LEEMAC 100 LST)......1342 / 1.00 <slowest>Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (WIZ-NEAR3 100 LST)...........1185 / 1.15 <fastest> (NEAREST41-VOVKA 100 LST).....1232 / 1.10 (TEST3-EVGENIY 100 LST).......1264 / 1.07 (CLOSEST-LEEMAC 100 LST)......1357 / 1.00 <slowest>Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (WIZ-NEAR3 100 LST)...........1170 / 1.15 <fastest> (NEAREST41-VOVKA 100 LST).....1201 / 1.12 (TEST3-EVGENIY 100 LST).......1264 / 1.06 (CLOSEST-LEEMAC 100 LST)......1341 / 1.00 <slowest>
(defun nearest42 (num lst / p a b) (if (vl-position num lst) num (if (zerop (setq lst (vl-sort (cons num lst) (function <)) p (vl-position num lst) ; faster than Evgeniy's when (> p 2) ; faster than wizman's when (not (equal p (length lst) 3)) ) ) (cadr lst) (if (= (last lst) num) (nth (1- p) lst) (if (> (- (setq a (nth (1+ p) lst)) num) (- num (setq b (nth (1- p) lst)))) b a ) ) ) ))
(setq lst '(10 20 30 40 50 60 70 80 90 100))(foreach num lst (print (setq num (1+ num))) (benchmark '((wiz-near3 num lst) (nearest42 num lst))))
11 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1485 / 1.03 <fastest> (WIZ-NEAR3 NUM LST).....1531 / 1.00 <slowest>21 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1500 / 1.04 <fastest> (WIZ-NEAR3 NUM LST).....1562 / 1.00 <slowest>31 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1500 / 1.02 <fastest> (WIZ-NEAR3 NUM LST).....1531 / 1.00 <slowest>41 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1516 / 1.03 <fastest> (WIZ-NEAR3 NUM LST).....1562 / 1.00 <slowest>51 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1500 / 1.03 <fastest> (WIZ-NEAR3 NUM LST).....1547 / 1.00 <slowest>61 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1515 / 1.03 <fastest> (WIZ-NEAR3 NUM LST).....1563 / 1.00 <slowest>71 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1531 / 1.02 <fastest> (WIZ-NEAR3 NUM LST).....1563 / 1.00 <slowest>81 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1546 / 1.01 <fastest> (WIZ-NEAR3 NUM LST).....1563 / 1.00 <slowest>91 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (WIZ-NEAR3 NUM LST).....1547 / 1.00 <fastest> (NEAREST42 NUM LST).....1547 / 1.00 <slowest>101 Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): (NEAREST42 NUM LST).....1484 / 1.06 <fastest> (WIZ-NEAR3 NUM LST).....1578 / 1.00 <slowest>
