Author Topic: ftp upload routine  (Read 7256 times)
TopoWAR
ftp upload routine
« on: December 05, 2012, 11:59:58 AM »
hello teachers, there is a routine that allows uploading files to an ftp server? I know of to lose, but I have not found anything up. Thanks for your attention.
Thanks for help
Re: ftp upload routine
« Reply #1 on: December 05, 2012, 12:50:17 PM »
vla-putremotefile immediately springs to mind, though I'm sure there are more advanced methods by interfacing with ActiveX objects outside of the AutoCAD Object Model.
irneb
« Reply #2 on: December 06, 2012, 04:20:11 AM »
TopoWAR
« Reply #3 on: December 06, 2012, 01:52:03 PM »
thanks lee-mac, but know how to apply vla-putremotefile, I know nothing of v-la ...
but I'll try
Thanks for help
« Reply #4 on: December 06, 2012, 06:01:41 PM »
thanks lee-mac, but know how to apply vla-putremotefile, I know nothing of vla- ...
putremotefile is a method of the VLA Utility object, hence you would call it as follows:
irneb
« Reply #5 on: December 06, 2012, 11:51:11 PM »
...you would call it as follows:...
Problem with the highlighted code - the vla-putremotefile links to the index page, but there's no such function listed (as I'd expect since its an ActiveX method - not a normal lisp function).
To use these you'd need to check the ActiveX help: http://entercad.ru/acadauto.en/index.html?page=idh_utility_object.htm
Also available as a chm file in your acad install: C:\Program Files\Common Files\Autodesk Shared\acadauto.chm
TopoWAR
« Reply #6 on: December 07, 2012, 08:39:18 AM »
I did as follows but only returns nil, that may be wrong?
(vla-putremotefile
       (vla-get-utility (vla-get-activedocument (vlax-get-acad-object)))
       "http://www.topowar.net/Otros"
       "c:\\leame.txt"
is supposed to ask for the username and password of ftp?
Thanks for help
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: December 07, 2012, 09:15:51 AM »
ftp://[User Name]:[Password]@[address]
as exempl:
ftp://UserName:MyPassword@ftp.thest.com
TopoWAR
« Reply #8 on: December 07, 2012, 09:21:37 AM »
ElpanovEvgeniy , fantastic, I'll prove it, thank you very much!
Thanks for help
bilançikur
« Reply #9 on: December 07, 2012, 10:35:14 AM »
Curious about where this might lead to, I tried the next code:
(vla-putremotefile
  "ftp://user:password@ftp.domain.com//public//sites//www.domain.com//files//"
  "c:\\test.dwg"
It returns:
  ;error: Automation Error. Inet: session connect failed
irneb
« Reply #10 on: December 08, 2012, 01:20:09 AM »
Could be any one of a number of reasons:
  • Username and/or password incorrect
  • URL incorrect
  • Path not existent
  • Insufficient rights to path (i.e. no write access)
  • Server down / hanging
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: December 08, 2012, 01:55:38 AM »
real test:
ftp://anonymous:test@ftp.autodesk.com
old autodesk FTP...
irneb
« Reply #12 on: December 08, 2012, 02:29:11 AM »
I think the issue is: this is testing a PUTremotefile. On that site the anonymous user does not have write access, so the function will fail.
The only way to test it would be to use a url to a server with a username which has write access.
Peter2
« Reply #13 on: May 15, 2017, 02:35:03 AM »
...  "ftp://user:password@ftp.domain.com//public//sites//www.domain.com//files//"...
I just failed with that code on two different ftp-addresses, and this is why I asked about the syntax of the address above
- "ftp" at the beginning (that's clear)
- "ftp" after @ - I'm not sure ..
- "www" in the middle of the address - ????
Is there some really special to consider?
« Last Edit: May 15, 2017, 04:49:06 PM by Peter2 »
Peter
BricsCAD V23
TopoWAR
« Reply #14 on: May 15, 2017, 10:55:29 AM »
I have tried in a thousand ways and I have not managed to make it work, maybe some teacher can collaborate with some test, thanks :-(
Thanks for help
