AutoCAD 2013 x86 SP1.1
I have some questions about the settings of a DimStyleTableRecord instance. Please, open the "Modify Dimension Style" dialog box (through _DIMSTYLE command, and press "Modify.." button) - my questions about these settings.
1. I try to set individual value for 'dimStyle.Dimblk1' property, but the "First" option on the "Symbols and Arrows" tab was not changed. Why it ain't working? How can I do it?
2. I try to set individual value for 'dimStyle.Dimblk2' property, but the "Second" option on the "Symbols and Arrows" tab was not changed. Why it ain't working? How can I do it?
3. How can I set value for a "Dimension Break" option on the "Symbols and Arrows" tab?
4. How can I set value for a "Linear Jog Size" option on the "Symbols and Arrows" tab?
5. How can I check/unchek the "Draw Frame Around Text" parameter on the "Text" tab?
6. How can I set "Scale Dimensions To Layout", or "Use Overall Scale Of" in "Scale for Dimension Features" group on "Fit" tab?
7. How can I check/uncheck the "Apply to Layout Dimensions Only" option on the "Primary Units" tab?
8. How can I set necessary value for "Placement" on "Alternate Units" tab?
9. How can I set a 'Basic', or a 'Deviation' value for a "Method" option in the "Tolerance Format" group, on the "Tolerances" tab?
10. How can I set an "Align Decimal Separators", or an "Align Operational Symbols" value for the "Align Decimal Separators" option in the "Tolerance Alignment" group on the "Tolerances" tab?
Best Regards,
Andrey
