Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How To Uncheck Radio Button
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How To Uncheck Radio Button (Read 1928 times)
Humbertogo
Guest
on:
October 05, 2012, 04:10:47 AM »
I have two boxed_radio_column, with a radio button that users must select.
[boxed_radio_column="A"]
[boxed_radio_column="B"]
I want to uncheck the check buttons if column A is check uncheck all buttons from column B
Logged
irneb
Water Moccasin
ACad R9-2016, Revit Arch 6-2016
WWW
Re: How To Uncheck Radio Button
Reply #1 on:
October 05, 2012, 04:33:12 AM »
Use the set_tile function. Set to an empty string to turn off all radio buttons in a cluster.
Code - Auto/Visual Lisp:
[Select]
set_tile
"radio-column-key"
Edit: Else (if you want a particular button to be turned on) set the value to the index if the button inside the cluster. E.g. to turn on the 3rd button:
[Select]
set_tile
"radio-column-key"
"2"
Last Edit: October 05, 2012, 04:37:19 AM by irneb
Logged
Humbertogo
Guest
Reply #2 on:
October 05, 2012, 04:54:46 AM »
Logged
irneb
Water Moccasin
WWW
Reply #3 on:
October 05, 2012, 04:59:13 AM »
Pleasure
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
