This video shows how to revise a pacman game level
http://www.youtube.com/watch?v=WN6778GV53o&feature=youtu.beIts the same if you are to add a new level, the new level have to be before the boss level which is the last level = level 16 then this boss level have to be in level 17.
Just move the boss level up by 25000 dwg unit and add the new level at 16. Follow this video. Then you have to map the boss level again
Yes, I admit it is design mistake by using level at 25000 dwg units. I should have all level run at the same spot, just insert the next level at same spot.
Anyway what is done is done. I am not going to change it. It took me 3 months to put all these together and now its up to my neck when I were to revise it.
get bored doing the same program nearly every day for 3 months.
Hope you understand, kruuger.
