If add == true, the object pointed to by obj is added to the top transaction. If add == false, then the object is removed from whatever transaction it's within.
Hi Kerry,
Yes, that's what I found in arxdoc.chm for AutoCAD 2010, too.
But what does it all mean? Why remove an object that's not yet been added?
Why remove an object from a transaction at all, and not plainly erase it from the database?
If the explanation quoted from the docs has hidden meanings, which I doubt, then I don't see them.
Documenting something is not just making lists and summing up. That documentation plainly stinks.
Thanks for the reply.
