Author Topic: Thoughts on a better ERASE command  (Read 5559 times)
Dave M
« on: June 14, 2012, 10:25:45 PM »
Allow me to throw down the gauntlet, and see if any skillful swampers have a routine that would work like I'm about to describe.
A polyline is created, and when you invoke the erase command (or any command that allows crossing polygon or window polygon), you have the ability to use the polyline you just created as either a window polygon, or a crossing polygon for selection.
Your reward?  My undying appreciation  ;-)
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Re: Thoughts on a better ERASE command
« Reply #1 on: June 14, 2012, 10:48:42 PM »
Grab the polyline coordinates then use ssget and wp?
danallen
« Reply #2 on: June 14, 2012, 11:08:22 PM »
Here is code for selecting:
;;;From: Joe Burke (joburke@hawaii.rr.com)
;;;Subject: Re: Polygon Selection Boundary
;;;Newsgroups: autodesk.autocad.customization
;;;Date: 2002-04-17 04:38:49 PST
;;;returns list of points in a pline
(defun-q C:SelectByPline (/ pline ptlist prev count)
 (princ "\nCrossing or Window selection?<C,W>")
 (setq typ (strcase (getstring)))
  ((= typ "W")
   (prompt "\nPick polyline to define Window selection set:")
  ((= typ "C")
   (prompt "\nPick polyline to define Crossing selection set:")
 (setq pline (car (entsel))
       ptlist (massoc 10 (entget pline))
  ((= typ "W")
   (setq prev (ssget "WP" ptlist))
   (setq count (sslength prev))
   (princ "\nThe Selection Set consists of ")
   (princ count)
   (princ " entities inside the Window Polygon.")
  ((= typ "C")
   (setq prev (ssget "CP" ptlist))
   (ssdel pline prev) ;remove pline from crossing ss
   (princ count)
   (princ " entities inside the Crossing Polygon.")
 (sssetfirst nil prev) ;select
);end defun
;;; massoc
;;; get multiple items from an association list (instead of just 1st one)
;;; From: Tony Tanzillo (tony.tanzillo@worldnet.att.net)
;;; Subject: Re: extracting multiple assoc from list
;;; Newsgroups: autodesk.autocad.customization
;;; Date: 1999/09/29
(defun-q massoc (key alist / x nlist)
  (foreach x alist
    (if (eq key (car x))
      (setq nlist (cons (cdr x) nlist))
  (reverse nlist)
) ;end defun
irneb
« Reply #3 on: June 15, 2012, 04:13:33 AM »
Slightly more concise:
  1.
  2. (defun massoc (key lst /)
  3.   (mapcar 'cdr (vl-remove-if-not '(lambda (item) (equal key (car item))) lst)))
  4.
  5. (defun c:EraseByPoly  (/ pEname pDxf ss)
  6.   (or *W/C* (setq *W/C* "CP"))
  7.   (while (progn (initget "CP WP F Undo")
  8.                 (setq pEname (entsel (strcat "\nSelect polyline border [WP/CP/F/Undo] <" *W/C* ">: "))))
  9.     (cond ((eq (type pEname) 'Str)
  10.            (if (eq pEname "Undo")
  11.              (command "_.Undo" "1")
  12.              (setq *W/C* pEname)))
  13.           ((and (eq (type pEname) 'List)
  14.                 (eq (type (setq pEname (car pEname))) 'EName)
  15.                 (eq (cdr (assoc 0 (setq pDxf (entget pEname)))) "LWPOLYLINE"))
  16.            (if (setq ss (ssget *W/C* (massoc 10 pDxf)))
  17.              (command "_.ERASE" (ssdel pEname ss) "")
  18.              (prompt "\nThere's no objects to erase.")))
  19.           (t (prompt "\nThat's not a polyline, please try again."))))
  20.   (princ))
Though for some reason I'm finding nothing selected through WP. Works fine for CP/F selection though.
« Reply #4 on: June 15, 2012, 08:05:44 AM »
My version:
  1. (defun c:perase ( / e s )
  2.     (while
  3.         (progn (setvar 'errno 0) (setq e (car (entsel)))
  4.             (cond
  5.                 (   (= 7 (getvar 'errno))
  6.                     (princ "\nMissed, try again.")
  7.                 )
  8.                 (   (eq 'ename (type e))
  9.                     (if (not (eq "LWPOLYLINE" (cdr (assoc 0 (entget e)))))
  10.                         (princ "\nSelected Object is not an LWPolyline.")
  11.                     )
  12.                 )
  13.             )
  14.         )
  15.     )
  16.     (if
  17.         (and e
  18.             (progn
  19.                 (initget "Window Crossing")
  20.                 (setq s
  21.                     (ssget
  22.                         (cond
  23.                             (   (eq "Window" (getkword "\nSpecify Selection Type [Window/Crossing] <Crossing>: "))
  24.                                 "_WP"
  25.                             )
  26.                             (   "_CP"   )
  27.                         )
  28.                         (apply 'append (mapcar '(lambda ( x ) (if (= 10 (car x)) (list (cdr x)))) (entget e)))
  29.                     )
  30.                 )
  31.                 (if s (ssdel e s))
  32.                 (< 0 (sslength s))
  33.             )
  34.         )
  35.         (command "_.erase" s "")
  36.     )
  37.     (princ)
  38. )
@Irné, hint: if pEname is not a member of ss, ssdel returns nil :wink:
irneb
« Reply #5 on: June 15, 2012, 08:50:59 AM »
@Irné, hint: if pEname is not a member of ss, ssdel returns nil ;)
Ah!  :-[ ... thanks for turning on the light! And for reminding me I don't need the vl-remove-* functions to get rid of nils: append does the same thing.
Now this works!
  1. (defun massoc  (key lst /)
  2.   (apply 'append (mapcar '(lambda (item) (if (equal key (car item)) (list (cdr item)))) lst)))
  3.
  4. (defun c:EraseByPoly  (/ pEname pDxf ss)
  5.   (or *W/C* (setq *W/C* "CP"))
  6.   (while (progn (initget "CP WP F Undo")
  7.                 (setq pEname (entsel (strcat "\nSelect polyline to [WP/CP/F/Undo] <" *W/C* ">: "))))
  8.     (cond ((eq (type pEname) 'Str)
  9.            (if (eq pEname "Undo")
  10.              (command "_.Undo" "1")
  11.              (setq *W/C* pEname)))
  12.           ((and (eq (type pEname) 'List)
  13.                 (eq (type (setq pEname (car pEname))) 'EName)
  14.                 (eq (cdr (assoc 0 (setq pDxf (entget pEname)))) "LWPOLYLINE"))
  15.            (if (and (setq ss (ssget *W/C* (massoc 10 pDxf)))
  16.                     (progn (ssdel pEname ss)
  17.                       (> (sslength ss) 0)))
  18.              (command "_.ERASE" ss "")
  19.              (prompt "\nThere's no objects to erase.")))
  20.           (t (prompt "\nThat's not a polyline, please try again."))))
  21.   (princ))
Dave M
« Reply #6 on: June 18, 2012, 11:43:58 AM »
Lee,
Thanks, this works perfectly!
Dave
« Reply #7 on: June 18, 2012, 11:51:02 AM »
You're very welcome Dave, I hope the code is comprehensible  :-)
huiz
  • Certified Prof C3D
« Reply #8 on: June 18, 2012, 03:24:13 PM »
I've seen a CookieCutter lisp somewhere which also erases everything inside or outside a polyline, and cut every line and block. Very usefull kind-of-an-erase tool. Actually, erase is an option but not required.
Another maybe great idea for a better erase command is to put elements in a recycle bin or something like that. If you open that drawing recycle bin, you see a drawing with everything you've erased and the possibility to restore the element.
« Reply #9 on: June 18, 2012, 03:48:14 PM »
http://www.theswamp.org/index.php?topic=24646.0  Trim with objects [CookieCutter] by Joe Burke
dgorsman
« Reply #10 on: June 18, 2012, 04:50:50 PM »
Like something that wblocks out the chunks (or even individual entities) as they are erased?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
huiz
« Reply #11 on: June 19, 2012, 03:45:48 AM »
Conceptual thinking, it would be very cool to have a recycle bin inside the drawing. Colleagues are able to undo erase actions, but customers shouldn't see the deleted items. So I think keeping the erased stuff inside the drawing is not a very good idea.
Maybe WBLOCK is an option. But your disk will be filled with garbage and it is hard to chain the erased elements to the original drawing.
I just think of another method, still conceptual (and I'm not sure if I will create this, but maybe I once will do ;-) ) what if there is an application which uses a Layout as a recycle bin. It redefines the ERASE command or using a reactor so the erased elements are moved to the Layout. The elements can keep the layer, color and linetype information. So all the elements are easily accessible to be restored, and it is also very easy to remove the Recycle Bin layout before sending the drawing to the customer.
irneb
« Reply #12 on: June 19, 2012, 04:22:32 AM »
You could always "send" the erased objects to a non-referenced block definition inside the DWG. That way the "trashbin" is not displayed in the DWG but easily restored by simply inserting that block @ 0,0,0 and exploding it. You could then wblock that block if you so want, or to clear it do a purge.
huiz
« Reply #13 on: June 19, 2012, 04:26:21 AM »
That is also a neat solution.
dgorsman
« Reply #14 on: June 19, 2012, 10:18:30 AM »
Slick.  Or something along the lines of the autosave cleaner which (under normal circumstances) cleans up after itself if the drawing is closed normally.
try {GreatPower;}
      {MasterBasics;}
