Another maybe great idea for a better erase command is to put elements in a recycle bin or something like that. If you open that drawing recycle bin, you see a drawing with everything you've erased and the possibility to restore the element.
Like something that wblocks out the chunks (or even individual entities) as they are erased?
Conceptual thinking, it would be very cool to have a recycle bin inside the drawing. Colleagues are able to undo erase actions, but customers shouldn't see the deleted items. So I think keeping the erased stuff inside the drawing is not a very good idea.
Maybe WBLOCK is an option. But your disk will be filled with garbage and it is hard to chain the erased elements to the original drawing.
I just think of another method, still conceptual (and I'm not sure if I will create this, but maybe I once will do
) what if there is an application which uses a Layout as a recycle bin. It redefines the ERASE command or using a reactor so the erased elements are moved to the Layout. The elements can keep the layer, color and linetype information. So all the elements are easily accessible to be restored, and it is also very easy to remove the Recycle Bin layout before sending the drawing to the customer.
