Author Topic: Create USFoot elevation surface from Metric DEM file  (Read 9101 times)
Re: Create USFoot elevation surface from Metric DEM file
« Reply #15 on: June 19, 2012, 03:49:45 PM »
Actually, now that I look at the downloaded files more closely, it appears the data is there but C3D is not reading it (or not reading it correctly).
Cathy
« Reply #16 on: June 19, 2012, 04:10:25 PM »
And now that I have downloaded the files, I see that they are not USGS .dem files.  It appears to me that they are ArcGIS ASCII grid files.  You might try GDAL translate.  http://www.gdal.org/index.html
I am still stuck in C3D 2008 -- not sure what version you are using, later versions may know how to read an ArcGIS ASCII grid file properly.
sdunn
« Reply #17 on: June 19, 2012, 06:43:12 PM »
Jeff,
If you create a regular surface file, you can add DEM data.  The missing zone information for the DEM can then be entered correctly.  It will still not adjust the vertical though.
« Reply #18 on: June 20, 2012, 01:22:18 AM »
I suggest new file from Metric template
new surface
insert the DEM data
Export to XML
New File from Imperial template
inport the XML file created above
Novarese
« Reply #19 on: June 20, 2012, 03:52:13 AM »
new surface
insert the DEM data
Export to XML
Brilliant, it works in my glorious Map2006.
I have no enough Ram to load http://data.tnris.org/data/Elevation/DEM_3296.zip so I tried with a small USGS dem (the Barringer crater in Arizona, UTM83 zone 12) surveyed in meters: check this out.
After your great tip, it appears like this in feet.
sdunn
« Reply #20 on: June 20, 2012, 09:07:42 AM »
new surface
insert the DEM data
Export to XML
This is what I am currently doing as a work-a-round.
I was playing with the GDAL utilities as suggested by Cathy and using them you can convert the grid file to a SHP contour file.  This can then be used to create a surface as well.
« Reply #21 on: June 20, 2012, 10:03:32 AM »
as far as I know the above is the only method that works correctly since C3D first appeared. (and in LDD)
Cathy
« Reply #22 on: June 20, 2012, 01:22:11 PM »
I would have used the GDAL utilities to create a USGS .dem file; I think it would be more accurate and C3D seems to know how to handle those properly
drizzt
« Reply #23 on: June 20, 2012, 06:42:07 PM »
drizzt, what tool did you use to scale the DEM elevations?  I am more interested in the method than getting the file converted.  This is not the only DEM file I am working with.  There are several work-a-rounds that I can do, but they are all convoluted and time consuming.  There are also a lot of crashes involved as most of the DEM files are pretty large.
I open with this http://www.bluemarblegeo.com/global-mapper/ then change the projection in global mapper and export dem, then inport into Civil
Novarese
« Reply #24 on: June 21, 2012, 06:29:48 AM »
Are you really sure the resulting Dem is in feet..?
If I open the huge http://data.tnris.org/data/Elevation/DEM_3296.zip in Microdem, I get such an info:
You'd better check out your Dem from GM, sir...
