Author Topic: Could some one help me plz , create Stations  (Read 7090 times)
HasanCAD
Re: Could some one help me plz , create Stations
« Reply #15 on: June 10, 2012, 10:31:43 AM »
This is Rev 1
;|---------------Layers List--------------------
    q_|_|| _\|| q_|| _\|
  Create stations for Prestresed tendon
  Author: Hasan M. Asous, 2010
ALL RIGHT RESERVED TO ALL
  Contact: HasanCAD @ TheSwamp.org,
           asos2000 @ CADTutor.net
           HasanCAD@gmail.com
  Version: 1      2012 06 10
________________________________________________
;     q_|_|| _\|| q_|| _\|     ;
;       Mainroutine Start      ;
(defun c:pts (/    p1 p2   tmp  step dist #pt ang  pang idx #pts
      Dst2 STxt Spt1 Spt2 Dst1 S    SS SS2  SS4  S42 X1
      X    XX XXA  XB   XAB  Lc   Lc1 LcD  a1   ys1 yc
      A    B y    yr
  (while T
    (if (and (setq p1 (getpoint "\nPick first point."))
     (setq p2 (getpoint p1 "\nPick second point."))
     (if (< (car p2) (car p1))
       (setq tmp p1 p1 p2 p2 tmp) T)
     (setq *L* (cond ((getint (strcat "\nWhat is HIGH Point <" (itoa (setq *L* (cond (*L*)
    (160)))) ">: " ))) (*L*)))
     (setq *c* (cond ((getint (strcat "\nWhat is LOW Point <" (itoa (setq *c* (cond (*c*) (35)))) ">: " ))) (*c*)))
     (setq step 1000)
     (setq dist (distance p1 p2))
     (setq #pt (fix (/ (/ dist step) 2)))
     (setq ang (angle p1 p2))
     (setq pang (+ ang (/ pi 2.)))
     (setq idx 1)
     (setq mp (list (/ (+ (car p1) (car p2)) 2)
    (/ (+ (cadr p1) (cadr p2)) 2))))
  (mapcar 'set '(p1 p2) (list p2 p1))
(makeline (polar (polar (trans p1 1 0) ang 0) pang 150)
  (polar (polar (trans p1 1 0) ang 0) pang -150)
(makeline (polar (polar (trans p2 1 0) ang 0) pang 150)
  (polar (polar (trans p2 1 0) ang 0) pang -150)
(makeline (polar (polar (trans mp 1 0) ang 0) pang 150)
  (polar (polar (trans mp 1 0) ang 0) pang -150)
(if (< (- (/ dist 2) (* #pt step)) 150)
    (setq #pts (- #pt 1))
    (repeat #pts
      (_repeat)
      (setq idx (1+ idx))
    (setq SPT11 (+ (* idx step) (- Dst2 (* idx step))))
    (setq STxt (itoa (fix (- (/ dist 2) (* #pts step)))))
    (setq Spt1 (polar (polar (trans p1 1 0) ang (* idx step))
      (+ pi pang)
      -250
    (setq
      Spt2 (polar (polar (trans p2 1 0) ang (- (* idx step)))
  (+ pi pang)
  -250
    (setq mps1 (list (/ (+ (car mp) (car Spt1)) 2)
     (/ (+ (cadr mp) (cadr Spt1)) 2)
    (setq mps2 (list (/ (+ (car mp) (car Spt2)) 2)
     (/ (+ (cadr mp) (cadr Spt2)) 2)
    (maketext STxt mps1 "0" 200 ang)
    (maketext STxt mps2 "0" 200 ang)
    (setq #pts #pt)
    (repeat #pts
      (_repeat)
      (setq idx (1+ idx))
    (setq LTxt (itoa (fix (- (/ dist 2) (* #pts step)))))
    (setq Lpt1 (polar (polar (trans p1 1 0) ang (* idx step))
      (+ pi pang)
      -250
    (setq
      Lpt2 (polar (polar (trans p2 1 0) ang (- (* idx step)))
  (+ pi pang)
  -250
    (maketext LTxt Lpt1 "0" 200 ang)
    (maketext LTxt Lpt2 "0" 200 ang)
;       Mainroutine End        ;
;       Subroutine Start       ;
(defun round (number by) ; http://www.theswamp.org/index.php?topic=3076.0;all
  (if (zerop by)
    number
    (+ (* (fix (/ number (setq by (abs by)))) by)
       (if (< (* 0.5 by) (rem number by))
by
0
; CAB  pre set to Middle Center
(defun maketext (str pt lyr ht rot)
  (entmakex (list (cons 0 "TEXT") ;***
  (cons 1 str) ;* (the string itself)
  (cons 6 "BYLAYER") ; Linetype name
  (cons 7 (getvar "TEXTSTYLE"))
;* Text style name, defaults to STANDARD, current
  (cons 8 (getvar "CLAYER")) ; layer
  (cons 10 pt) ;* First alignment point (in OCS)
  (cons 11 pt) ;* Second alignment point (in OCS)
  (cons 39 0.0) ; Thickness (optional; default = 0)
  (cons 40 ht) ;* Text height
  (cons 41 0.8) ; Relative X scale factor, Width Factor, defaults to 1.0
  (cons 50 rot) ; <<<----- RJP ADDED Text rotation angle
  (cons 51 0.0) ; Oblique angle
  (cons 62 256) ; color
  (cons 71 0) ; Text generation flags
  (cons 72 1) ; Horizontal text justification type
  (cons 73 2) ; Vertical text justification type
  (cons 210 (list 0.0 0.0 1.0))
(defun makeline (p1 p2)
  (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))
(defun _repeat (/)
  (equation)
  (maketext yt (polar (polar (trans p1 1 0) ang X1) (+ pi pang) 250)
    "0"
    200
    ang
  (makeline (polar (polar (trans p1 1 0) ang X1) pang 150)
    (polar (polar (trans p1 1 0) ang X1) pang -150)
  (maketext yt (polar (polar (trans p2 1 0) ang (- X1)) (+ pi pang) 250)
    "0"
    200
    ang
  (makeline (polar (polar (trans p2 1 0) ang (- X1)) pang 150)
    (polar (polar (trans p2 1 0) ang (- x1)) pang -150)
(defun equation (/)
  (setq Dst2 (/ Dist 2)
Dst1 (* 0.1 Dist)
S    (* 0.8 Dist)
SS   (* S S)
SS2  (/ SS 2)
SS4  (/ SS 4)
S42  (- SS4 SS2)
X1   (* idx step)
X    (- (* idx step) Dst1)
XX   (* X X)
Lc   (- *L* *c*)
Lc1  (* Lc 0.1)
LcD  (* Lc1 Dist)
a1   (/ LcD Dst2)
ys1  (- *L* a1)
yc   (- *c* ys1)
A    (/ yc S42)
AS   (* A S)
B    (- AS)
XXA  (* A XX)
XB   (* B X)
XAB  (+ XXA XB)
y    (+ XAB ys1)
yt   (rtos (round y 5) 2 0)
(defun *error* (msg)
  (and oldNomutt (setvar 'nomutt oldNomutt))
  (cond ((not msg)) ; Normal exit
((member msg '("Function cancelled" "quit / exit abort")))
; <esc> or (quit)
((princ (strcat "\n** Error: " msg " ** ")))
  ) ; Fatal error, display it
  (if result
    result
;        Subroutine End        ;
(princ "\n Type  PTS  to Invoke")
« Last Edit: June 10, 2012, 10:38:36 AM by HasanCAD »
