Author Topic: Find the angle degree between three points  (Read 9551 times)
Coder
« on: May 02, 2012, 06:41:30 AM »
Hello
I am not doing good at maths , and I need to find the angle degree ( or radians ) between tow lines to insert an elbow ( Block ) at the angle
according to its correct degree .
Hope that make sense .
Thank you all
Re: Find the angle degree between three points
« Reply #1 on: May 02, 2012, 06:45:57 AM »
Of course, there are two angles between three points, the sum of which equals 2pi rads (360 degs). The following function will return the smaller of these angles (in radians):
  1. ;; Get Inside Angle  -  Lee Mac
  2. ;; Returns the smaller angle subtended by three points with vertex at p2
  3.
  4. (defun LM:GetInsideAngle ( p1 p2 p3 )
  5.     (   (lambda ( a ) (min a (- (+ pi pi) a)))
  6.         (rem (+ pi pi (- (angle p2 p1) (angle p2 p3))) (+ pi pi))
  7.     )
  8. )
Conversion to degrees is simple:
  1. (defun rtd ( r ) (* 180.0 (/ r pi)))
« Reply #2 on: May 02, 2012, 06:59:11 AM »
Or here's another using vector calculus:
  1. ;; 3-Point Angle  -  Lee Mac
  3.
  4. (defun LM:3pAngle ( p1 p2 p3 )
  5.     (   (lambda ( a b ) (acos (/ (vxv a b) (* (norm a) (norm b)))))
  6.         (mapcar '- p3 p2)
  7.         (mapcar '- p1 p2)
  8.     )
  9. )
  10.
  11. ;; Vector Dot Product  -  Lee Mac
  12. ;; Args: u,v - vectors in R^n
  13.
  14. (defun vxv ( u v )
  15.     (apply '+ (mapcar '* u v))
  16. )
  17.
  18. ;; Vector Norm (R^n)  -  Lee Mac
  19. ;; Args: v - vector in R^n
  20.
  21. (defun norm ( v )
  22.     (sqrt (apply '+ (mapcar '* v v)))
  23. )
  24.
  25. ;; ArcCosine  -  Lee Mac
  26. ;; Args: -1 <= x <= 1
  27.
  28. (defun acos ( x )
  29.     (if (<= -1.0 x 1.0)
  30.         (atan (sqrt (- 1.0 (* x x))) x)
  31.     )
  32. )
« Reply #3 on: May 02, 2012, 10:14:19 AM »
Lets see if I can state the problem for the OP.
Is this what you are looking for?
« Last Edit: May 02, 2012, 06:00:21 PM by CAB »
« Reply #4 on: May 02, 2012, 06:02:41 PM »
If so maybe this will get you started.  See drawing attached.
(defun c:Insert90 (/ p1 p2 p3 BlkName)
  (setq BlkName "ELL90deg"
        PipeSize 6.0)
  (defun lm:getinsideangle (p1 p2 p3)
    ((lambda (a) (min a (- (+ pi pi) a)))
  ;;  Convert  Radians to Degrees
  (defun rtod (r) (* 180.0 (/ r pi)))
  ;;D. C. Broad, Jr.
  ;;(sideof <ray-origin> <another-point-on-ray> <point-to-be-tested>)
  (defun sideof (p1 p2 p / r)
    (setq r (cond
              ((equal p1 p 1e-10) 0)
              (t (sin (- (angle p1 p) (angle p1 p2))))
    (if (equal r 0 1e-10) 0 r)
  ;;return values
  ;;negative = point is to the right side of the ray
  ;;0 = point is on the ray
  ;;otherwise point is on the left side of the ray.
  ;;P1 should not equal P2 for meaningful results.
  (if (and
        (setq p1 (getpoint "\nPick first point."))
        (setq p2 (getpoint "\nPick intersecting point."))
        (setq p3 (getpoint "\nPick third point."))
      ((or (zerop (setq result (sideof p1 p2 p3)))
           (not (equal (lm:getinsideangle p1 p2 p3) (/ pi 2) 0.001))
       (princ "\nError - not 90 degrees")
      ((minusp result) ; right turn ell
       (command "-insert" BlkName "_non" p2 PipeSize "" (rtod(angle p3 p2)))
      (t ; Left turn ell
       (command "-insert" BlkName "_non" p2 PipeSize "" (rtod(angle p1 p2)))
Coder
« Reply #5 on: May 03, 2012, 12:23:50 AM »
Hi .
Lee , that's really nice , and it works very good . But I can't understand what the second codes for (post #2) ?  :-)
They seem very hard to me .
CAB , that's exactly what I am after , and I would like to understand how codes are running ( to understand coding ) . :-)
Many thanks .
« Reply #6 on: May 03, 2012, 06:19:09 AM »
The function in post#2 is solving the problem using vector calculus, rather than the in-built AutoLISP angle function, which is dependent on the current construction plane.
The function merely uses the definition of the Vector Dot Product:
a·b = |a||b|cosθ
rearranged for theta:
θ = acos(a·b/|a||b|)
