Author Topic: code that does the trick as the command -view  (Read 4315 times)
Coder
« on: April 19, 2012, 02:16:47 AM »
Hello everybody .
How to do a named view with lisp without using command call ?
Many thanks
Stefan
Re: code that does the trick as the command -view
« Reply #1 on: April 19, 2012, 02:56:56 AM »
Explore properties and methods for Views collection.
Coder
« Reply #2 on: April 19, 2012, 03:22:04 AM »
Thank you Stefan .
I tried to change the center point and the start with the end points of the view , but I could not . :oops:
Can you please take a look  .... ?
(setq v (vla-item (vla-get-views (vla-get-ActiveDocument (vlax-get-acad-object))) "MyView"))
(vla-put-center v (vlax-3d-point '(10.0 10.0))) ;;; this is return error
(vla-put-startpoint v (vlax-3d-point '(10.0 10.0))) ;;; this is return error
(vla-put-endpoint v (vlax-3d-point '(50.0 50.0))) ;;; this is return error
Stefan
« Reply #3 on: April 19, 2012, 04:18:24 AM »
Center point is a 2d coordinate
View object doesn't have StartPoint and EndPoint properties. Do you mean Height and Width?
If you are looking for a view delimited by '(10 10) and '(50 50) corners, try
  1. (setq v (vla-Add views "MyView"))
  2.
  3. (setq p1 '(10. 10.)
  4.       p2 '(50. 50.)
  5.       c1 (mapcar '(lambda (x y) (* 0.5 (+ x y))) p1 p2)
  6.       ds (mapcar 'abs (mapcar '- p1 p2)))
  7.
  8. (vlax-put v 'Center c1)
  9. (vlax-put v 'Height (cadr ds))
  10. (vlax-put v 'Width (car ds))
Coder
« Reply #4 on: April 19, 2012, 04:30:42 AM »
Very nice , thanks a lot Stefan  :-)
One last question please .
why this did not work ?
(vla-put-center v (vlax-3d-point '(25.0 25.0 0.0)))
kruuger
« Reply #5 on: April 19, 2012, 04:35:20 AM »
small tip. center of view is not in center if view is rotated.
http://www.theswamp.org/index.php?topic=38126.msg431906#msg431906
k.
Stefan
« Reply #6 on: April 19, 2012, 04:42:55 AM »
vlax-3d-point create a 3d coordinate and Center property require a 2D coordinate
  1. (vla-put-Center v (vlax-make-variant
  2.                     (vlax-safearray-fill
  3.                       (vlax-make-safearray vlax-vbDouble '(0 . 1))
  4.                       '(25. 25.)
  5.                       )
  6.                     )
  7.   )
Coder
« Reply #7 on: April 19, 2012, 04:50:40 AM »
  4.                       '(25. 25.)
  5.                       )
  6.                     )
  7.   )
That's great Stefan . it is a very kind of you to spend that time for me with the clear explanations .
Many thanks  :-)
