Author Topic: Can't copy and paste  (Read 11462 times)
AUTOKAD
« on: April 11, 2012, 11:35:57 AM »
All of a sudden, I can't copy and paste. What's wrong? dont ask wether layers are locked or in paperspace..i know all these stuff..its just that copy and paste is not working! please help. thanks
M-dub
Re: Can't copy and paste
« Reply #1 on: April 11, 2012, 11:38:34 AM »
Restart AutoCAD?
Rob...
« Reply #2 on: April 11, 2012, 11:40:13 AM »
Object Enablers? Improper file conversion? One file? All files?
CAD Tech
« Reply #3 on: April 11, 2012, 12:50:19 PM »
Is it only one file?
Can you Select from one file and Rt-Click drag the objects into another tiled drawing window?
Is it text or drawing objects that won't copy and paste?
Is the Rt-Click menu option missing?
Does using the keyboard shortcuts work?
Are you stuck in REFEDIT mode?
Matt__W
  • I like my water diluted.
« Reply #4 on: April 11, 2012, 01:09:16 PM »
Is it turned on??  Plugged in??   :lol:
Autodesk Expert Elite
« Reply #5 on: April 11, 2012, 01:09:45 PM »
+1
dgorsman
« Reply #6 on: April 11, 2012, 01:53:07 PM »
"I know all this stuff" is open to interpretation, very hard to determine what you've actually tried.   :angel:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #7 on: April 11, 2012, 02:51:00 PM »
Yeah, he knows ALL this stuff, except you know, why he can't copy and paste.  ;-)
« Reply #8 on: April 11, 2012, 03:15:33 PM »
Hotfix - Cut and Paste
acdb17.dll (dll - 8642Kb)
Readme (htm - 9Kb)
This hotfix will correct a problem where cut and paste, copy and paste, block and insert, wblock and insert, and drag and drop operations fail in drawings that are saved in AutoCAD® 2000 and AutoCAD® Release 14 file formats.
If you open or create a file in AutoCAD 2007 and save it in AutoCAD 2000 or AutoCAD Release 14 file formats and then open the drawing in AutoCAD 2000, 2000i, 2002 or AutoCAD Release 14 and attempt to cut and paste, copy and paste, block and insert, wblock and insert, or drag and drop objects, then these operations will fail.
cmwade77
« Reply #9 on: April 12, 2012, 11:37:58 AM »
One possibility that I haven't seen mentioned, which always seems to happen every three years around this time of year is:
If you have upgraded to AutoCAD 2013, you cannot copy from AutoCAD 2013 to an older version of AutoCAD, due to the new file format.
