Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Extract Dynamic Block 's properties
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Extract Dynamic Block 's properties (Read 3504 times)
Coder
Swamp Rat
on:
April 03, 2012, 07:16:39 AM »
hello everyone .
is it possible to extract all properties of a dynamic block to the command line ?
Thank you .
Logged
Stefan
Bull Frog
The most I miss IRL is the Undo button
Re: Extract Dynamic Block 's properties
Reply #1 on:
April 03, 2012, 08:11:18 AM »
LIST command will show you all properties available for current VisibilityState.
Logged
Coder
Swamp Rat
Reply #2 on:
April 03, 2012, 08:15:21 AM »
Thanks Stefan .
I want to get that by code and specifically the properties' names that are found in a dynamic block .
Logged
alanjt
Needs a day job
Standby for witty remark...
WWW
Reply #3 on:
April 03, 2012, 08:20:00 AM »
Code - Auto/Visual Lisp:
[Select]
vla
GetDynamicBlockProperties
vla
object
or
[Select]
vlax-invoke
vla
object
'GetDynamicBlockProperties
Logged
Dropbox
Coder
Swamp Rat
Reply #4 on:
April 03, 2012, 08:31:00 AM »
Thank you so much alanjt
That's what I was after .
Logged
alanjt
Needs a day job
WWW
Reply #5 on:
April 03, 2012, 08:36:31 AM »
No problem. Good luck.
Logged
Dropbox
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
