Author Topic: quoting polyline  (Read 4621 times)
Lupo76
quoting polyline
« on: April 02, 2012, 10:34:54 AM »
Hello everyone,
I have to create a function that fits the dimensions along the segments of a polyline.
I have made ​​this function, but is not able to manage the arcs present in a polyline.
In fact to obtain the vertices of the polyline using the following function:
(defun vertexpoli (oggreg / coords n p listavertex)
  (setq coords (vla-get-coordinates (vlax-ename->vla-object oggreg)))
  (setq coords (vlax-safearray->list (vlax-variant-value coords)))
  (setq n 0)
  (setq p (list (nth n coords)  (nth (+ n 1) coords)))
  (repeat (/ (length coords) 2)
      (if listavertex
        (setq listavertex (append (list p) listavertex))
        (setq listavertex (list p))
      (setq n (+ n 2))
  listavertex
Can you give me some advice on how to implement it, add to the list, the data of the arcs?
efernal
Re: quoting polyline
« Reply #1 on: April 02, 2012, 12:50:41 PM »
one way:
see dxf code 42 (bulge)
find out the included angle and  divide by 2.0
find out the distance between start point and end point
use half of this distance and half of included angle to calculate radius, so length will be radius * included angle
e.fernal
irneb
« Reply #2 on: April 03, 2012, 01:22:02 AM »
If it's just a situation of wanting points on the arc vectors or their arc lengths, then perhaps look into the vlax-curve-* functions.
ribarm
  • Marko Ribar, architect
« Last Edit: April 03, 2012, 03:08:02 AM by ribarm »
M.R. on Youtube
Lupo76
« Reply #4 on: April 03, 2012, 12:20:25 PM »
What to say ....  :-)
I did not think just find all this code ready!  :lmao:
Thank you!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: April 04, 2012, 08:06:25 AM »
Thank you!
  1. (defun test (e)
  2.   ;; (test (car(entsel)))
  3.   (vl-remove nil
  4.              (mapcar (function (lambda (a b)
  5.                                  (if (= (car a) 10)
  6.                                    (list (cdr a) (cdr b))
  7.                                  )
  8.                                )
  9.                      )
  10.                      (entget e)
  11.                      (cdddr (entget e))
  12.              )
  13.   )
  14. )
test:
'(((1728.94 1778.07) 0.0)
  ((1945.34 1892.39) 0.0)
  ((2269.92 1759.53) 0.0)
  ((2671.7 2161.3) -0.694158)
  ((3098.4 1966.54) 0.0685342)
  ((3135.5 1404.21) -0.538618)
  ((2647.19 915.904) -0.187763)
  ((1973.16 1351.68) -0.851784)
  ((2147.77 1526.3) 1.95618)
  ((2147.77 1635.94) -0.23567)
  ((1715.03 1564.88) 1.02521)
« Reply #6 on: April 04, 2012, 08:12:46 AM »
Another :-)
  1. (defun _lwvertices ( e )
  2.     (if (setq e (member (assoc 10 e) e))
  3.         (cons
  4.             (cons
  5.                 (cdr (assoc 10 e))
  6.                 (cdr (assoc 42 e))
  7.             )
  8.             (_lwvertices (cdr e))
  9.         )
  10.     )
  11. )
(_lwvertices (entget (car (entsel))))
    ((-230.89 -9.2228) . 0.0)
    ((-221.288 16.2617) . -0.495079)
    ((-201.074 22.3174) . 0.553551)
    ((-185.407 28.6254) . 0.0)
    ((-190.208 48.3065) . 0.0)
    ((-206.633 48.3065) . 0.0)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: April 04, 2012, 08:13:31 AM »
for test:
  1. (defun test1 (/ l)
  2.   (setq l (test (car (entsel "\n Select LWPOLYLINE:"))))
  3.     (append (list '(0 . "LWPOLYLINE")
  4.                   '(100 . "AcDbEntity")
  5.                   '(67 . 0)
  6.                   '(410 . "Model")
  7.                   '(8 . "0")
  8.                   '(62 . 1)
  9.                   '(100 . "AcDbPolyline")
  10.                   (cons 90 (length l))
  11.                   '(70 . 0)
  12.             )
  13.             (apply (function append)
  14.                    (mapcar (function (lambda (a) (list (cons 10 (car a)) (cons 42 (cadr a))))) l)
  15.             )
  16.     )
  17.   )
  18.   (princ)
  19. )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: April 04, 2012, 08:18:10 AM »
Hi Lee Mac!  :-)
Great idea to use recursion - got short and clear!
ps. long time no theme challenge...
bored  :-D
« Reply #9 on: April 04, 2012, 08:34:47 AM »
Hi Lee Mac!  :-)
Thank you! Your method was also very interesting  :-)
Another for Polyline:
  1. (defun _vertices ( e / l )
  2.     (if (eq "VERTEX" (cdr (assoc 0 (setq l (entget e)))))
  3.         (cons
  4.             (cons
  5.                 (cdr (assoc 10 l))
  6.                 (cdr (assoc 42 l))
  7.             )
  8.             (_vertices (entnext e))
  9.         )
  10.     )
  11. )
bored  :-D
 :lol:  A challenge is long overdue  :lol:
irneb
« Reply #10 on: April 04, 2012, 08:59:56 AM »
Sorry to chip in, had to have a go at this too  :angel:
ActiveX version works on both LWPoly and old Poly:
  1.
  2. (defun ExtractVertices  (ename / obj lst n)
  3.   (setq obj (vlax-ename->vla-object ename) n 0)
  4.   (vl-remove-if
  5.     'null
  6.     (mapcar
  7.       '(lambda (a b / m)
  8.          (setq m n n (1+ n))
  9.          (if (= (rem m 2) 0) (cons (cons a b) (vla-GetBulge eo (/ m 2)))))
  10.       (setq lst (vlax-get eo 'Coordinates))
  11.       (cdr lst))))
irneb
« Reply #11 on: April 04, 2012, 09:39:50 AM »
That actually gave me an idea ... what about a grouping function to get around that hassle of ActiveX coordinates: http://www.theswamp.org/index.php?topic=41419.0
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: April 04, 2012, 11:42:56 AM »
  1. (defun f (o i)
  2.     (cons (cons (vlax-curve-getPointAtParam o i) (vla-getbulge o i)) (f o (1+ i)))
  3.   )
  4. )
test:
  1. (f (vlax-ename->vla-object(car(entsel))) 0)
