Author Topic: changing dimstyle scale factor  (Read 6780 times)
Stefan
Re: changing dimstyle scale factor
« Reply #15 on: March 14, 2012, 05:12:27 PM »
Please re-read:  :roll:
If the DimStyle is the active DimStyle, you will also need to change the DIMSCALE System Variable to the same value, otherwise this will act as an override to the DimStyle settings.
You are right about that.
Sorry, happens all the time...   :-D
