Author Topic: database changes command HIDEOBJECTS  (Read 2127 times)
Harrie
« on: March 08, 2012, 07:32:59 AM »
In AutoCAD 2011 you have the command HIDEOBJECTS
and UNISOLATEOBJECTS.
This is not done with the DXF code 60!
Like the program INVIS.lsp
http://www.cadtutor.net/forum/showthread.php?59655/page2
This is also not done with the Visible property!
(vlax-put-property (vlax-ename->vla-object (car (entsel))) 'Visible 0)
What are the database changes, when I use the
command HIDEOBJECTS.
Regards.
« Last Edit: March 08, 2012, 11:25:17 AM by Harrie »
Harrie
Re: database changes command HIDEOBJECTS
« Reply #1 on: March 09, 2012, 09:28:17 AM »
I think it is in the dictionary "ACAD_OBJECTISOLATION".
(setq dic (dictsearch (namedobjdict) "ACAD_OBJECTISOLATION"))But I can't see the names of the entities.
Regards.
« Reply #2 on: March 09, 2012, 10:09:39 AM »
Indeed, the XRecord stored in that Dictionary doesn't reveal much at all; neither does Google  :-(
« Reply #3 on: March 13, 2012, 10:22:45 AM »
This is the only thing I was able to ascertain from the ACAD_OBJECTISOLATION Dictionary:
  1.   (
  2.     (-1 . <Entity name: 7ef03b08>)
  3.     (0 . "XRECORD")
  4.     (5 . "501")
  5.     (102 . "{ACAD_REACTORS")
  6.     (330 . <Entity name: 7ef01c60>)
  7.     (102 . "}")
  8.     (330 . <Entity name: 7ef01c60>)
  9.     (100 . "AcDbXrecord")
  10.     (280 . 1)
  11.     (70 . 7) ;; <---  This increments whenever HIDEOBJECTS, ISOLATEOBJECTS or UNISOLATEOBJECTS is used.
  12.     (70 . -1)
  13.   )
Other than that, this feature doesn't appear to be exposed to LISP :-(
« Last Edit: March 13, 2012, 10:30:13 AM by Lee Mac »
alanjt
  • Standby for witty remark...
« Reply #4 on: March 13, 2012, 03:10:41 PM »
That's a bummer.
Dropbox
Matt__W
  • I like my water diluted.
« Reply #5 on: March 13, 2012, 03:43:01 PM »
Have you tried INSPECTOR??
Autodesk Expert Elite
