Then build it the way I showed in the firsst case and add in the Shoulder Extended SubBase, etc, etc... and all should be well.
If you folks are using a SHARED tool palette you could complete the assembly, and then drag and drop it onto your standard sections palette for this project. That would take the 'work' out of it for them, or just pace the finished assembly in the design file for them to use in the corridor.
If it's gravel..make one that is pavement...and one that is gravel and assign the correct pay items.
