Author Topic: <Help>How Add a transparent command (can be invoked when other command is runnin  (Read 3058 times)
chlh_jd
Hi all master , how to add a command can be invoked when other command is running not though type in "'cmd" .
In the following Example ,  it can be use like --->"MOVE"--->"'SS"..., but how can I use it like osnap command  method  --->"MOVE"--->"SS"
(defun SS_SS (/ ss1 i lst s1 layer_fili ss2 filiter pt)
  ;;layer-filter
  (defun ss-sel-grread (/ is_go_on)
     (setq is_go_on T)
      (while (and
       is_go_on
       (setq pt (grread t 4 2))
       (/= 3 (car pt))
       (/= 25 (car pt))
  ((and (= 2 (car pt))
(eq (strcase (chr (cadr pt))) "N")
   (prompt "Select Characteristic Objects :")
   (setq ss1 (ssget))
   (setq is_go_on nil)
  (t
   (if (= (car PT) 5)
     (setq id_go_on nil)
  (if ss-filiter-old-ss
      (prompt "Existing layer filters, Need to be rebuilt please type N:")
      (ss-sel-grread)
      (setq ss1 (ssget))
  (if ss1
      (setq
i   -1
lst nil
      (while (setq s1 (ssname ss1 (setq i (1+ i))))
(setq lst (append lst (list (cdr (assoc 8 (entget s1))))))
      (setq
layer_fili
  (vl-string-right-trim
    (apply (function strcat)
   (mapcar (function (lambda (x) (strcat x ","))) lst)
filiter   (list (cons 8 layer_fili))
ss-filiter-old-ss filiter
    (setq filiter ss-filiter-old-ss)
  (if filiter
      (setq pt (cadr pt))
      (if (and pt (listp pt))
(SendKeys (ss-pt->str pt))
      (setq ss2 (ssget filiter))
    (ss_ss)
  (prompt
    (strcat (rtos (sslength ss2) 2 0) " Objects are selected .")
  ss2
(defun SendKeys (keys / ws)
  ;;Send keys to command-line
  (setq ws (vlax-create-object "WScript.Shell"))
  (vlax-invoke-method ws (quote sendkeys) keys)
  (vlax-release-object ws)
);_end SendKeys
(defun ss-pt->str (pts / str)
  ;;translate point into string for command-line
  (if (numberp (car pts))
      (setq str "")
      (foreach a pts
(setq str (strcat str (strcat (rtos a 2 6) ",")))
      (setq str (vl-string-right-trim "," str))
      (strcat str " ")
    (mapcar (function ss-pt->str) pts)
;;;ADD command ,which can be invoked when other command is running .
(vlax-add-cmd "SS" 'ss_ss "SS" 7)
;;;Use method in command-line , e.g.
;;;                                 "MOVE" "'SS"
or this way will be better
(defun C:SS (/ ss1 i lst s1 layer_fili ss2 filiter pt)
  ;;layer-filter
     (setq is_go_on T)
      (while (and
       is_go_on
       (/= 3 (car pt))
       (/= 25 (car pt))
   (setq ss1 (ssget))
   (setq is_go_on nil)
  (t
   (if (= (car PT) 5)
     (setq id_go_on nil)
      (ss-sel-grread)
      (setq ss1 (ssget))
  (if ss1
      (setq
i   -1
lst nil
      (setq
layer_fili
  (if filiter
      (setq pt (cadr pt))
    (C:SS)
  (prompt
  ss2
« Last Edit: February 09, 2012, 07:25:14 AM by chlh_jd »
VovKa
  • Ukraine
you just don't want to type in an apostrophe? am i right?
chlh_jd
Hi Lee , I've try the vlax-add-cmd method .
Hi VovKa , You're right .
VovKa
  • Ukraine
MOVE command is expecting a certain set of keywords, but SS is not in that set. so i don't think you can avoid an apostrophe (for command) or a parentheses (for function)
as to your code, why not make it simpler?
(defun c:SS (/ EntName)
    (if (setq EntName (car (entsel "\nselect filter object: ")))
(ssget (list (assoc 8 (entget EntName))))
irneb
Yes, I also don't think you can get away from the apostrophe. You could of course add the macro (including the apostrophe) as a keyboard shortcut in CUI.
BTW, your code seems to do a subset of my old Select Similar: http://forums.augi.com/showthread.php?t=66329
It also works as transparent, but also only with the apostrophe.
« Last Edit: February 08, 2012, 03:57:15 AM by irneb »
codered8x
Thank Lee for Auto/Visual lisp online help ! useful for reading on phone.
Thank Se7en for that - its certainly a nice feature  :-)
chlh_jd
It can be simply . but before you select objects , you must select char objects every time . So I save the filter as global variable .
