Author Topic: Delete a layer using objectdbx  (Read 2817 times)
GDF
« on: January 23, 2012, 11:58:33 pm »
Using Lee's ObjectDBX Wrapper routine:
http://www.theswamp.org/index.php?topic=31827.msg373958#msg373958
I am trying to delete a layer. I keep running into problems...Key not found.
Also, I guess a tblsearch cannot be done in objectdbx.
(defun ARCH:DEL-LAY (layer_name / n ent acapp acsp adoc allrs layer_name TotalNumber CurrNumber)
  (setq acapp (vlax-get-acad-object)
adoc  (vla-get-activedocument acapp)
acsp  (vla-get-block (vla-get-activelayout adoc))
allrs (vla-get-layers adoc)
  (or (eq (vla-get-freeze (vla-item allrs layer_name)) :vlax-true)
    (vla-put-freeze (vla-item allrs layer_name) :vlax-false)
  (or (eq (vla-get-lock (vla-item allrs layer_name)) :vlax-true)
    (vla-put-lock  (vla-item allrs layer_name) :vlax-false)
  (or (eq (vla-get-layeron (vla-item allrs layer_name)) :vlax-false)
    (vla-put-layeron (vla-item allrs layer_name) :vlax-true)
  (vlax-for lt (vla-get-layouts adoc)
    (vlax-for ob (vla-get-block lt)
      (if (eq (vla-get-layer ob) layer_name)
(vla-delete ob)
(vlax-release-object ob)
(defun ARCH:DBX-LAY-DBX ( )
  (if (tblsearch "layer" "A-REVS-SYMB")(ARCH:DEL-LAY "A-REVS-SYMB"))
(defun C:TEST ()
  (ARCH:LOAD (strcat ARCH#UTIF "ObjectDBXBase.lsp"))
  (LM:ODBX (ARCH:DBX-LAY-DBX) nil t)
AutoCAD 2012x64 Windows 7x64
  • AutoCAD 2015 Windows 7 London, England
Re: Delete a layer using objectdbx
« Reply #1 on: January 24, 2012, 08:05:48 am »
Hi Gary,
When working with ObjectDBX you are working with the ObjectDBX Document Object, not the ActiveDocument, so the function supplied to my ObjectDBX Wrapper function will need to require a single argument - the ObjectDBX Document.
Try the following, (though, I haven't tested it):
  1. (defun ARCH:DEL-LAY ( doc name / layer )
  2.    (if
  3.        (null
  4.            (vl-catch-all-error-p
  5.                (setq layer
  6.                    (vl-catch-all-apply 'vla-item (list (vla-get-layers doc) name))
  7.                )
  8.            )
  9.        )
  10.        (progn
  11.            (vl-catch-all-apply 'vla-put-freeze (list layer :vlax-false))
  12.            (vla-put-lock layer :vlax-false)
  13.            (vla-put-layeron layer :vlax-true)
  14.
  15.            (vlax-for block (vla-get-blocks doc)
  16.                (vlax-for obj block
  17.                    (if (eq name (vla-get-layer obj)) (vla-delete obj))
  18.                )
  19.            )
  20.            (vl-catch-all-apply 'vla-delete (list layer))
  21.            t ;; Success!
  22.        )
  23.    )
  24. )
  25.
  26. (defun ARCH:DEL-LAY-DBX ( doc )
  27.    (ARCH:DEL-LAY doc "A-REVS-SYMB")
  28. )
  29.
  30. (defun C:TEST ( )
  31.    (ARCH:LOAD (strcat ARCH#UTIF "ObjectDBXBase.lsp"))
  32.    (LM:ODBX 'ARCH:DEL-LAY-DBX nil t)
  33. )
  34.
It will Thaw / Unlock / Turn On the layer (if it exists), then iterate over all blocks in the drawing (including Modelspace / Paperspace blocks), then, for each block, will iterate over all objects in the block. If the object resides on the layer in question, the object will be deleted.
Finally, the function attempts to delete the layer from the layer collection.
GDF
« Reply #2 on: January 24, 2012, 08:28:09 am »
Thank you Lee.
PERFECT!!!
You just made my day and saved me a lot of time.
I didn't know enough to figure this one out.
Gary
« Reply #3 on: January 24, 2012, 08:34:46 am »
Excellent Gary, I'm delighted to hear that it worked for you  :-)
Cheers,
Lee
GDF
« Reply #4 on: January 24, 2012, 03:33:51 pm »
Lee
Using the modified ARCH:DEL-LAY function...
Is it possible to delete more than one layer at a time, reading from a list?
Below example does not work:
(defun ARCH:DBX_DelLay (doc) (ARCH:DEL-LAY doc (list "A-REVS-CLOD" "A-REVS-SYMB")))
(defun C:REVS  ()
  (LM:ODBX 'ARCH:DBX_DelLay nil t)
« Reply #5 on: January 24, 2012, 03:42:40 pm »
The easiest modification would be:
  2.    (if
  3.        (null
  5.                (setq layer
  7.                )
  8.            )
  9.        )
  10.        (progn
  14.
  18.                )
  19.            )
  21.            t ;; Success!
  22.        )
  23.    )
  24. )
  25.
  27.    (foreach layer '("A-REVS-CLOD" "A-REVS-SYMB")
  28.        (ARCH:DEL-LAY doc layer)
  29.    )
  30. )
  31.
  32. (defun C:TEST ( )
  33.    (ARCH:LOAD (strcat ARCH#UTIF "ObjectDBXBase.lsp"))
  34.    (LM:ODBX 'ARCH:DEL-LAY-DBX nil t)
  35. )
But that is MASSIVELY inefficient, since every object in the drawing is being iterated for every layer.
Instead, consider this variation:
  1. (defun ARCH:DEL-LAYS ( doc layers / dbxlayers layer objlst )
  2.    (setq dbxlayers (vla-get-layers doc))
  3.    (foreach name layers
  4.        (if
  5.            (null
  6.                (vl-catch-all-error-p
  7.                    (setq layer
  8.                        (vl-catch-all-apply 'vla-item (list dbxlayers name))
  9.                    )
  10.                )
  11.            )
  12.            (progn
  13.                (vl-catch-all-apply 'vla-put-freeze (list layer :vlax-false))
  14.                (vla-put-lock layer :vlax-false)
  15.                (vla-put-layeron layer :vlax-true)
  16.                (setq objlst (cons layer objlst))
  17.            )
  18.        )
  19.    )
  20.    (if objlst ;; If at least one of the layers exists
  21.        (progn
  22.            (vlax-for block (vla-get-blocks doc)
  23.                (vlax-for obj block
  24.                    (if (member (vla-get-layer obj) layers) (vla-delete obj))
  25.                )
  26.            )
  27.            (foreach layer objlst
  28.                (vl-catch-all-apply 'vla-delete (list layer))
  29.            )
  30.            t ;; Success for at least one of the layers
  31.        )
  32.    )
  33. )
  34.
  35. (defun ARCH:DEL-LAYS-DBX ( doc )
  36.    (ARCH:DEL-LAYS doc '("A-REVS-CLOD" "A-REVS-SYMB"))
  37. )
  38.
  39. (defun C:TEST ( )
  40.    (ARCH:LOAD (strcat ARCH#UTIF "ObjectDBXBase.lsp"))
  41.    (LM:ODBX 'ARCH:DEL-LAYS-DBX nil t)
  42. )
Again, both are untested.
GDF
« Reply #6 on: January 24, 2012, 04:02:38 pm »
Lee
Just tried out your modified "Instead, consider this variation" version.
It works beautifully. Thanks again.
I use theis routine to remove all revision clouds and delta symbols from a old job that is being reused and renamed.
A GREAT time saver and way much faster than using a script file.
Thanks again for posting your "ObjectDBX Wrapper" routine. I will be using it one more in the future, when I come up with other needs to clean up whole directories of drawings.
Gary
I can sit back a have a cold one now!
« Reply #7 on: January 24, 2012, 04:47:16 pm »
That's great Gary, I'm really pleased that the ObjectDBX Wrapper is of use to you  :-)
Enjoy your beverage  8-)
saycaphe
« Reply #8 on: June 26, 2012, 01:34:56 am »
Hi guys.
I try to use the ObjectDBX Wrapper and code that Lee-Mac posted above to delete layers name "tekst" "markering" in DXF files, but it does not work.
Can you help me to make it work with there DXF file i've uploaded.
« Reply #9 on: June 26, 2012, 06:45:42 am »
AFAIK, you cannot use ObjectDBX to interface with DXF files, only with DWG / DWT / DWS.
BlackBox
« Reply #10 on: June 26, 2012, 05:15:00 pm »
For those that may not already have it:
Autodesk // Labs_ | ScriptPro for AutoCAD
"Potential has a shelf life." - Margaret Atwood
« Reply #11 on: August 10, 2015, 04:58:59 am »
434939575,
Please do not use the Report to Moderator system to ask questions ... just post your question in the thread.
The reporter has made the following comment:
Friend, can I DBX delete a layer? My English is not good!
--> Donate to theSwamp<--
Azi!
  • Mosquito
« Reply #12 on: November 14, 2017, 03:47:28 am »
Hi Gary
Please explain how to use it
Many Thanks in advance
