Author Topic: Getting a Point3DCollection of specific osnaps  (Read 1498 times)
gablackburn
« on: January 20, 2012, 11:54:47 AM »
I'd like to get a Point3DCollection of all the endpoints of lines in a particular layer but I haven't found a way to do it.
I can figure out how to do it for blocks, but up until this point, I've never needed it for osnaps.
Dim myEndPtColl As New Point3dCollection
Dim myPointFilter(1) As DatabaseServices.TypedValue
myPointFilter(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode.LayerName, "WALLS")
myPointFilter(1) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode. ????? OSMODE 1 ?????)
Is this possible or am I going about this the wrong way?
Thanks in advance,
G.A. Blackburn
edit:  PS - I'm using VB.NET
gile
  • Marseille, France
Re: Getting a Point3DCollection of specific osnaps
« Reply #1 on: January 20, 2012, 04:28:41 PM »
It looks like you're going the wrong way. You cannot select "EndPoints" only entities as lines.
So, select the lines, then iterate through the selection to get each line EndPoint.
gablackburn
« Reply #2 on: January 26, 2012, 12:41:56 PM »
Thanks for the response gile, sorry it took so long but I was out of town.   Although I didn't post the code, I will be creating a selection set of all the lines in the WALLS layer.  I'll see if I can cycle through to get the 3D coordinates of the endponts.
