Author Topic: --{challenge}--How many 1's at least?  (Read 2820 times)
highflyingbird
  • Later equals never.
« on: January 13, 2012, 09:33:42 AM »
If a number is  composed entirely of 1's? ->   111...1,
How many  1's  at least  can compose a number ,which can be divided exactly by 2011?
« Last Edit: January 13, 2012, 11:58:29 AM by HighflyingBird »
I am a bilingualist,Chinese and Chinglish.
irneb
Re: --{challenge}--How many "1"s at least?
« Reply #1 on: January 13, 2012, 09:59:25 AM »
Brute force method:
(defun Smallest1 (n / d)
  (setq d 1.)
  (while (and (not (equal (rem d n) 0. 1.e-16)) (< d 1.797693134862315e308))
    (setq d (+ (* d 10.) 1.))
  d
Result:
_$ (Smallest1 2011)
1.11111e+233
I don't think it's the correct one though: 233 - 1's. But it's as close as AutoLisp is going to get to it using just its internal data structures. You'd probably get a better result if you could use BigInts and run it for several days.
highflyingbird
« Reply #2 on: January 13, 2012, 11:01:10 AM »
Brute force method:
  (setq d 1.)
  d
Result:
_$ (Smallest1 2011)
1.11111e+233
No,it's not the exactly answer.Thank you anyway.
« Reply #3 on: January 13, 2012, 11:36:00 AM »
So you are looking for the smallest multiple of 2011 composed entirely of 1's?
highflyingbird
« Reply #4 on: January 13, 2012, 11:48:51 AM »
This is my answer.
« Last Edit: January 13, 2012, 12:05:04 PM by HighflyingBird »
« Reply #5 on: January 13, 2012, 11:48:56 AM »
Numbers of the form 1, 11, 111 can be expressed as: (1/9)*(10n-1)
So you are looking for the smallest 'n' such that (1/18099)*(10n-1) = integer?
highflyingbird
« Reply #6 on: January 13, 2012, 12:01:10 PM »
Lee,thank you.  I'm sorry for my bad grammar and expression.
« Reply #7 on: January 14, 2012, 08:10:28 AM »
This is my answer.
Very clever HighflyingBird - I really like your method of removing the multiples of '111...1' by way of 'rem' before multiplying the result so as not to hit the numerical limit for doubles. My naiive method would have been similar to Irneb's.
ElpanovEvgeniy
  • Moscow (Russia)
Re: --{challenge}--How many 1's at least?
« Reply #8 on: January 14, 2012, 12:43:53 PM »
my way:
  1. (defun test3 (/ I X)
  2.   (setq i 5
  3.         x (rem 11111 2011)
  4.   )
  5.   (while (not (member x '(203 20 201 0)))
  6.     (setq i (+ i 4)
  7.           x (rem (+ (* x 10000) 1111) 2011)
  8.     )
  9.   )
  10.   (+ i (vl-position x '(0 201 20 203)))
  11. )
_$ (BenchMark '((test1) (test2) (test3)))
Benchmarking ..............Elapsed milliseconds / relative speed for 2048 iteration(s):
    (TEST3).....1062 / 4.81 <fastest>
    (TEST1).....2781 / 1.84
    (TEST2).....5109 / 1.00 <slowest>
_$
« Reply #9 on: January 14, 2012, 12:56:52 PM »
 :-o
qjchen
  • Best wishes to all
« Reply #10 on: January 14, 2012, 08:52:16 PM »
This is my solution by Lisp
  1. ;;by qjchen
  2. (defun c:test (/ i d)
  3.   (setq i 1 d 1)
  4.   (while (not (zerop d))
  5.     (if (zerop (setq d (rem (+ (* 10 d) 1) 2011))) (princ (1+ i)) (setq i (1+ i)))
  6.   )
  7.   (princ)
  8. )
  9.
and this is by Python, Brute force is adopted. Python support big num operation, and the speed is acceptable.
Code - Python: [Select]
  1. sum=0
  2. for i in range(0,2000):
  3.     sum=sum*10+1
  4.     if(sum%2011==0):
  5.         print (i+1)
  6.
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
irneb
« Reply #11 on: January 16, 2012, 02:53:39 AM »
It would have been possible to use BigNum in CLisp / Scheme as well, but AutoLisp is restricted to 32bit integers  :ugly: ... thanks ADesk! :realmad:
But HyflyingBird & Evgeniy's workaround is truly awesome! Glad there is a way!
