Author Topic: Bicursion ...  (Read 18426 times)
uncoolperson
Re: Bicursion ...
« Reply #30 on: November 07, 2005, 11:10:18 PM »
I already knew it was broken... ("("(5 4 3 ) nil ")") is a real good time.
it was just humorous
Re: Bicursion ...
« Reply #31 on: November 07, 2005, 11:42:39 PM »
FLAME ON:
That type of post, particularly a supposed code solution, is not worth the bandwidth it takes to send it.
It's illogical and poorly reasoned. The rest of the world agrees with me.
FLAME OFF:
uncoolperson
Re: Bicursion ...
« Reply #32 on: November 08, 2005, 11:11:14 AM »
FLAME ON:
now where'd i put that fire extiguisher.... :roll:
hunterxyz
Re: Bicursion ...
« Reply #33 on: September 15, 2007, 12:25:25 AM »
Asked wants can let the result with what method equate to this ?
(setq lst '("A" ("B1" "B2" "B3" "B4" "B5") "C" "D" "E"))
=> (("A")
    (nil "B1")
    (nil "B2")
    (nil "B3")
    (nil "B4")
    ("C")
    ("D")
    ("E")
(setq lst '(10 (20.1 20.2 20.3 20.4 20.5) 30 40 50))
=> ((10)
    (nil 20.1)
    (nil 20.2)
    (nil 20.3)
    (nil 20.4)
    (30)
    (40)
    (50)
(setq lst '(10 (20 21 (22.1 22.2 (22.30 22.31 22.32) 22.4) 23 24) 30 (40 41 42) 50))
=> ((10)
    (nil 20)
    (nil 21)
    (nil nil 22.1)
    (nil nil 22.2)
    (nil nil nil 22.3)
    (nil nil nil 22.31)
    (nil nil nil 22.32)
    (nil nil 22.4)
    (nil 23)
    (nil 24)
    (30)
    (nil 40)
    (nil 41)
    (nil 42)
    (50)
Re: Bicursion ...
« Reply #34 on: September 15, 2007, 11:33:22 AM »
I'm not sure what you're asking, but if you use the final function I
penned from this discussion and use it to process the three samples
you provided --
(   (lambda ( / flatten )
        (defun flatten ( lst / f1 f2 )
            (defun f1 ( lst )
                (apply 'append
                    (mapcar 'f2 lst)
            (defun f2 ( x / a )
                (if x
                    (if (listp x)
                        (if (listp (setq a (car x)))
                            (append (f1 a) (f1 (cdr x)))
                            (cons a (f1 (cdr x)))
                        (list x)
                   '(nil)
            (f1 lst)
        (mapcar 'print
            (mapcar 'flatten
It outputs this --
("A" "B1" "B2" "B3" "B4" "B5" "C" "D" "E")
(10 20.1 20.2 20.3 20.4 20.5 30 40 50)
(10 20 21 22.1 22.2 22.3 22.31 22.32 22.4 23 24 30 40 41 42 50)
Which in my mind faithfully honors the original intent of the function.
Hope that helps / clarifies.
Cheers and welcome to the swamp.
hunterxyz
Re: Bicursion ...
« Reply #35 on: September 15, 2007, 09:29:36 PM »
Thank you the suggestion
Re: Bicursion ...
« Reply #36 on: September 16, 2007, 11:53:18 AM »
You're very welcome.
