We are in the beginning phases of migrating from LD to Civil3D. We do both surveying and civil design, so getting our many descriptor keys ready has been a daunting task. So, I finally got a complete version and wanted to test regular points and survey points. I have a survey flle that plots a pair of points and eventually should plot lines between the linear items.
But I noticed a difference in the coordinates between my survey points and regular points. Turns out , my civil 3d template was still set to international feet, but the default setting for a new survey network is us survey feet.
When you review the coordinates in the panorama, they both list the coordinates from the survey file. But the survey points, when reviewed in graphics, are not at the listed coordinates.
Once I changed my file units to us feet, the points aligned. Bottom line, you better be aware of the units in use of all files used in all projects!
