it seems that 'User defined language' doesn't support 'Fold/Unfold'
Yep, that's one of the gripes I have with N++. I just use the built-in lisp language and add the keywords to that. There's only 3 reasons I can state as absolute musts for using N++ over VLIDE: (1) folding, (2) regex search & replace, (3) html formatted export. So if one of those aren't available, N++ is next to useless for me - but now I use the
SciTE editor, thus far so good.
I don't use the AutoComplete - I'd rather want something like you get in Visual Studio (i.e. a drop-down of available functions / variables as you type). Perhaps something using the
Scintilla's AutoComplete/CallTip. Wish they implemented SciTE with that ... perhaps I'd look into trying it on for size.
BTW, anyone used an editor which can export to forum formatting instead of HTML? The HTML works "fine" until you edit a post, then you loose indents and line-breaks ... for some reason :ugly: . Would have been great if the forum used similar code to the
GeSHi package of MediaWiki. It already has a cadlisp code type which formats AutoLisp specific - thus you just need to copy the code as is, no pre-formatting required.
