Author Topic: QLEADER settings  (Read 5968 times)
PHX cadie
Re: QLEADER settings
« Reply #15 on: September 26, 2005, 03:51:53 PM »
CAB,
 I really like those leaders also. Will try @ home.
Acad 2013 and XM
hyposmurf
« Reply #16 on: September 26, 2005, 04:40:51 PM »
Without LISP or a macro my QLEADER text will justify left once it set once.Close and ropen the drawing and its still set that way.I guess this is due to that being a setting rather than  system variable.I was just looking for a fool proof way for the qlqeader text to always left justify.Now Im working with CAD full time Im beginning to realise the importance of having little shortcuts for common tasks that always produce the same result.
PHX cadie
« Reply #17 on: September 27, 2005, 09:55:22 PM »
CAB,
 How do I get at the "Fat Leaders"? Either I'm doing something wrong, but the link seems to take me back to theswamp's home page.
Acad 2013 and XM
« Reply #18 on: September 27, 2005, 10:22:17 PM »
I fixed the link, so try again.
Be sure you check out the other routines i that thread.
PHX cadie
« Reply #19 on: September 27, 2005, 10:51:44 PM »
Thanks,
 As always I feel guilty about being a pain, but nothing seems to easy for me. Copied fatl into notepad, saved as fatl.lsp, loaded succesfully but after picking 3 points it disappears and I get this:
Command: _appload fatl.lsp successfully loaded.
Command:
Type  FatL  to runmalformed list on input; error: An error has occurred inside
the *error* functionAutoCAD variable setting rejected: "cmdecho" nil
Command:
Command: fatl
            Fat Leader - Version 1.0
Pick from leader start point:
no function definition: @DELTA; error: An error has occurred inside the *error*
Did I goof? Sorry but I really really  really really really like those leaders  :cry:
Acad 2013 and XM
« Reply #20 on: September 27, 2005, 11:13:50 PM »
Well you have fallen victim to the dreaded 'Missed a part of the text" copy gremlin. :-)
See the attached lisp file. It should work for you.
PHX cadie
« Reply #21 on: September 27, 2005, 11:22:00 PM »
$#@$% gremlims (they've been following me for years)
With the block manager and now fatl's, I was thinkin,......can you upload you're whole drive??  :-D
Thanks Again sir, you're awesome !!!!!!
Acad 2013 and XM
