Author Topic: How to get area?  (Read 5642 times)
litss
How to get area?
« on: October 18, 2011, 05:16:37 AM »
I have got a list of line ends, like ((pt1 pt2) (pt3 pt4) (pt5 pt6) ...). And these lines form a closed area (only one), but some of them connect by ends and others cross each other, which means it could be rectangle or "#".
How could I get the area of the closed area? I've tried: draw the lines->pick a point manually within the closed area->genrate a region->get the area. But here, a manual point is required.
If "regen" is the only way, how can I omit the "pick point" step? Or, there is another better way to solve the problem?
irneb
Re: How to get area?
« Reply #1 on: October 18, 2011, 05:59:54 AM »
Depending on how complex the shape defined is, and if you're only using lines: Then you could use the inters function to find those intersections, generate a LWPolyline from those points and get it's area property.
Of course you'd need to find the correct order for these intersections though, otherwise you could end up with a self-intersecting polyline. Thus your area would be smaller than it should.
« Reply #2 on: October 18, 2011, 09:16:10 AM »
If you have a set of points describing a simple (non-intersecting) polygon, you can use the equation from here to calculate the enclosed area, e.g.:
(defun PointArea ( lst )
        (abs
            (apply '+
                (mapcar
                    (function
                        (lambda ( a b ) (- (* (car a) (cadr b)) (* (car b) (cadr a))))
                    lst (append (cdr lst) (list (car lst)))
        2.0
litss
« Reply #3 on: October 18, 2011, 09:17:13 PM »
Thanks U guys!
To irneb: :( I have tried to collect points before. But I have no idea how to arrange them in the right order. So I finally gave up that thought.
To Lee: Does ur routine require a arranged points-lst? I haven't tried it. If not, the same problem.
pBe
« Reply #4 on: October 18, 2011, 11:45:39 PM »
USe something like this in conjunction with Lee's code
(defun c:test (/ sort_ ss i ent pts_ ll)
(defun sort_ (lst / a  mList intr)
    (while (setq a (car lst))
  (foreach itm (setq lst (vl-remove a lst))
  (if (setq intr (inters (car a)(cadr a)
                       (car itm)(cadr itm) ))
     (setq mList (cons intr mList))))
  mList
  (setq ss (ssget '((0 . "LINE"))))
  (repeat (setq i (SSLENGTH ss))
  (setq ent (entget (ssname ss (setq i (1- i))))
  (setq pts_ (cons (list (cdr (assoc 10 ent))
  (cdr (assoc 11 ent))) pts_)))
(if (= (length  (setq ll (sort_ pts_))) 4)
    (princ (strcat "\nArea: "(rtos (pointarea (list (cadr ll)
(car ll)
(caddr ll)
(last ll)
) 2 4)))
   )(princ)
Hope this helps
litss
« Reply #5 on: October 19, 2011, 09:24:19 PM »
Thx pBe!
I will try ur code soon. It must be helpful.
alanjt
  • Standby for witty remark...
« Reply #6 on: October 20, 2011, 07:53:32 AM »
Dropbox
litss
« Reply #7 on: October 20, 2011, 11:40:43 AM »
To pBe: I've tried ur code. It works well with closed area with 4 lines. But failed with more than 4. I am not quite sure why.
To Lee: Ur code works. But it did require an arranged pts. Otherwise, returns unexpected value.
To alanjt: Thank you. Ur code is amzing. Though it is not perfectly meet my situation. I can't point out he vertex one by one to get the area. There are too many.
Thx again for all of u. I'll try to arrange the intersections. Then I will use Lee's code.
« Reply #8 on: October 20, 2011, 11:57:14 AM »
Yes, the points must outline the area, since the equation will only apply to simple (non-self-intersecting) polygons.
alanjt
« Reply #9 on: October 20, 2011, 12:58:30 PM »
Why not use BPoly and pick a point within your intersecting lines and get the area from the created polyline?
Dropbox
litss
« Reply #10 on: October 20, 2011, 09:37:19 PM »
alanjt:  Well, to manually pick a point within the area is my current way. The difference is I generate a "region", not a pline. I just wanna improve and make it more automaticly.  Maybe I can try to find out a point within the area automaticly. That will do too.  Thx!
pBe
« Reply #11 on: October 21, 2011, 12:56:12 AM »
Of course, its written that way to do as such  :)
Might as well :)
Tell you what, post an image or a dwg sample.
litss
« Reply #12 on: October 21, 2011, 02:08:02 AM »
Here are the samples. I am wishing to get the areas of all shadowed automaticly while I "ssget" the lines at one time. It might be too difficult for me. So I am planning to "ssget" one by one :), without picking a point within it.
pBe
« Reply #13 on: October 21, 2011, 03:02:26 AM »
Tell me this, if you're going to select the lines one by one anyway, you might as well pick a point rather than select the lines:
8 lines , 8 input
8 points, 8 input
Alanjt's posted link will take care of the area once you have the points in order, which is very likely so as you are picking the points in order
or why not?
The plines generated by BPoly can be easily converted to a region and just one pick point.
we can play around with codes to suit your needs, but there are other options to consider first.
So give us an outline
How:<-------- sequence that is
What:<--- the result  (besides the area value of course)
« Last Edit: October 21, 2011, 03:09:00 AM by pBe »
irneb
« Reply #14 on: October 21, 2011, 03:08:54 AM »
I can think of a way using polar to figure out the direction around the shape for most of those. The problem one would be that Z shape.
As a test I tried figuring out if a hatch would work, though then you get all sorts of strange artifacts. So bang goes that idea. It seems your best bet is to use the boundary though trying to figure out the "internal" point would be very similar to trying to figure out the order of the intersections.
