Is it possible to perform an e-transmit while you are in a command? I.e. have the e-transmit complete while the command is still active.
What I would like to do is during the middle of my command perform the e-transmit and when it is finished I validate the resulting zip file and decide whether to continue running the command or exit.
The way I am currently performing the e-transmit is via SendCommand or SendStringToExecute and this won't run until the command is through.
string command =string.Concat( "-ETRANSMIT\nC\n", path,"\n" );
m_doc.SendStringToExecute(command, true, false, false);
Is there some otherway to perform the e-transmit?
