Author Topic: Ploting only in grayscale  (Read 3319 times)
MUQTAR
« on: October 09, 2011, 05:16:11 PM »
my plotter printing grayscale i m trying to change to original black and white but is same please help me some one to solve this problem. we are using hp plotter in network sharing
Re: Ploting only in grayscale
« Reply #1 on: October 10, 2011, 06:50:16 AM »
Change the Pen Table assignment that your Page Setup is using to Gray Scale and verify that it is set to Shades of gray and using the corect percent black as desired.
MUQTAR
« Reply #2 on: October 11, 2011, 09:54:26 AM »
thanks for reply but still same problem i check my pen assignment it is OK please if you have any other way please help me
thanks, :-)
« Reply #3 on: October 12, 2011, 06:39:40 AM »
Please note the attached image below
This is an image of the autodesk provided GREYSCALE CTB
you will notice that even when one choses this CTB that the screening is set to 100%....this is a backward notation indicating that the line will be 100% BLACK
NOT
That it would be screened 100% which would yield a line one could not see at all....
Keep this in mind and adjust your CTB accordingly.
MUQTAR
« Reply #4 on: October 12, 2011, 03:40:02 PM »
thanks its work
