/// <include file='./SymbolTableExtensionMethods.xml' path='Documentation/Item[@Name="SymbolTableExtensionMethods"]/Methods/Method[@Name="Has_1"]/*'/>public static bool Has(this SymbolTable table, string name, bool checkErased) { bool result = false; using (Transaction t = table.Database.TransactionManager.StartTransaction()) { foreach (ObjectId id in table) { if ((checkErased && id.IsErased) || !id.IsErased) { SymbolTableRecord tr = t.GetObject<SymbolTableRecord>(id, OpenMode.ForRead, true); result = tr.Name.Equals(name, StringComparison.CurrentCultureIgnoreCase); } if (result) break; } } return result;}
[CommandMethod("hasTest", CommandFlags.Modal)] public void hasTest() { Document dwg = acad.DocumentManager.MdiActiveDocument; Editor ed = dwg.Editor; Database db = dwg.Database; //names of new layers string name1 = "Layer1"; string name2 = "Layer2"; //add new layers using (Transaction t = db.TransactionManager.StartTransaction()) { LayerTable lt = (LayerTable) t.GetObject(db.LayerTableId, OpenMode.ForWrite); LayerTableRecord ltr = new LayerTableRecord() { Name = name1 }; lt.Add(ltr); LayerTableRecord ltr2 = new LayerTableRecord() { Name = name2 }; lt.Add(ltr2); t.AddNewlyCreatedDBObject(ltr, true); t.AddNewlyCreatedDBObject(ltr2, true); t.Commit(); } //delete one layer using (Transaction t = db.TransactionManager.StartTransaction()) { LayerTable lt = (LayerTable) t.GetObject(db.LayerTableId, OpenMode.ForWrite); LayerTableRecord ltr = (LayerTableRecord) t.GetObject(lt[name1], OpenMode.ForWrite); LayerTableRecord ltr2 = (LayerTableRecord) t.GetObject(lt[name2], OpenMode.ForWrite); ltr.Erase(true); t.Commit(); bool param = false; //search Layer1 by name ed.WriteMessage("Search {0} by name, with parameter '{1}'. Result: {2}\n", name1, param, lt.Has(name1, param) ? "It is found" : "It is not found"); param = !param; ed.WriteMessage("Search {0} by name, with parameter '{1}'. Result: {2}\n", name1, param, lt.Has(name1, param) ? "It is found" : "It is not found"); param = false; //search Layer2 by name ed.WriteMessage("Search {0} by name, with parameter '{1}'. Result: {2}\n", name2, param, lt.Has(name2, param) ? "It is found" : "It is not found"); param = !param; ed.WriteMessage("Search {0} by name, with parameter '{1}'. Result: {2}\n", name2, param, lt.Has(name2, param) ? "It is found" : "It is not found"); } }
Command: hasTestSearch Layer1 by name, with parameter 'False'. Result: It is not foundSearch Layer1 by name, with parameter 'True'. Result: It is not foundSearch Layer2 by name, with parameter 'False'. Result: It is foundSearch Layer2 by name, with parameter 'True'. Result: It is found
/// <include file='./SymbolTableExtensionMethods.xml' path='Documentation/Item[@Name="SymbolTableExtensionMethods"]/Methods/Method[@Name="Has_1"]/*'/> public static bool Has(this SymbolTable table, string name, bool checkErased) { bool result = false; Database db = table.Database; List<SymbolTableRecord> records = new List<SymbolTableRecord>(); using (Transaction t = db.TransactionManager.StartTransaction()) { for (long i = db.BlockTableId.Handle.Value; i < db.Handseed.Value; i++) { ObjectId id = ObjectId.Null; Handle h = new Handle(i); if (db.TryGetObjectId(h, out id) && id.IsValid && id.ObjectClass.Name.EndsWith("TableRecord")) { SymbolTableRecord tr = (SymbolTableRecord) t.GetObject(id, OpenMode.ForRead, true); if (tr.OwnerId == table.ObjectId) records.Add(tr); } } foreach (SymbolTableRecord tr in records) { if ((checkErased && tr.IsErased) || !tr.IsErased) { result = tr.Name.Equals(name, StringComparison.CurrentCultureIgnoreCase); } if (result) break; } } return result; }
Command: hasTestSearch Layer1 by name, with parameter 'False'. Result: It is not foundSearch Layer1 by name, with parameter 'True'. Result: It is foundSearch Layer2 by name, with parameter 'False'. Result: It is foundSearch Layer2 by name, with parameter 'True'. Result: It is found
I rewrite my method. It works:
static class Extensions { [System.Security.SuppressUnmanagedCodeSecurity] [DllImport( "acdb18.dll", CallingConvention = CallingConvention.ThisCall, CharSet = CharSet.Unicode, EntryPoint = "?getAt@AcDbSymbolTable@@QEBA?AW4ErrorStatus@Acad@@PEB_WAEAVAcDbObjectId@@_N@Z")] public static extern ErrorStatus getAt( IntPtr symbolTable, string name, out ObjectId id, bool getErased ); public static ObjectId GetSymbolTableRecordId( SymbolTable table, string name, bool getErased ) { ObjectId id = ObjectId.Null; ErrorStatus es = getAt(table.UnmanagedObject, name, out id, getErased); return id; } public static bool Has(this SymbolTable table, string name, bool checkErased) { ObjectId oid = GetSymbolTableRecordId(table, name, checkErased); return !oid.IsNull; } }
/// <include file='./SymbolTableExtensionMethods.xml' path='Documentation/Item[@Name="SymbolTableExtensionMethods"]/Common/*'/> public static class SymbolTableExtensionMethods { /// <include file='./SymbolTableExtensionMethods.xml' path='Documentation/Item[@Name="SymbolTableExtensionMethods"]/Methods/Method[@Name="Has_1"]/*'/> public static bool Has(this SymbolTable table, string name, out ObjectId objId, bool checkErased) { return Has(table, out objId, checkErased, tr => tr.Name.Equals(name, StringComparison.CurrentCultureIgnoreCase)); } /// <include file='./SymbolTableExtensionMethods.xml' path='Documentation/Item[@Name="SymbolTableExtensionMethods"]/Methods/Method[@Name="Has_2"]/*'/> public static bool Has(this SymbolTable table, ObjectId objId, bool checkErased) { ObjectId id = ObjectId.Null; return Has(table, out id, checkErased, tr => tr.ObjectId == objId); } /// <include file='./SymbolTableExtensionMethods.xml' path='Documentation/Item[@Name="SymbolTableExtensionMethods"]/Methods/Method[@Name="Has_3"]/*'/> public static bool Has(this SymbolTable table, out ObjectId objId, bool checkErased, Func<SymbolTableRecord, bool> func) { bool result = false; ObjectId _id = ObjectId.Null; using (Transaction t = table.Database.TransactionManager.StartTransaction()) { SymbolTableRecord tr = null; SymbolTable st = (SymbolTable) t.GetObject(table.ObjectId, OpenMode.ForRead); st = st.IncludingErased; foreach (ObjectId id in st) { if ((checkErased && id.IsErased) || !id.IsErased) { tr = (SymbolTableRecord) t.GetObject(id, OpenMode.ForRead, true); result = func(tr); } if (result) { _id = tr.ObjectId; break; } } } objId = _id; return result; } }
i think from version A2010 and onwards, theres an 'IncludingErased' property under the symboltable class... this may help out?cheers, Mark
