Author Topic: Download file from internet  (Read 7782 times)
TopoWAR
« on: October 06, 2011, 12:49:57 PM »
Hi Everyone! Is there any way to download a file online? for example, "http://www.opendcl.com/version/version.txt"
thanks
Thanks for help
Re: Download file from internet
« Reply #1 on: October 06, 2011, 12:53:16 PM »
See here and here.
VovKa
  • Ukraine
« Reply #2 on: October 06, 2011, 01:04:27 PM »
you don't have to save the file just to know the odcl's version
(defun vk_GetRemoteText (RemoteFileName / objHTTP Result)
    (if (setq objHTTP (vlax-create-object "WinHTTP.WinHTTPRequest.5.1"))
        (progn (setq
                   Result (vl-catch-all-apply
                              (function
                                  (lambda ()
                                      (vlax-invoke-method
                                          objHTTP       "Open"
                                          "GET"         RemoteFileName
                                          :vlax-false
                                      (vlax-invoke objHTTP "Send")
                                      (vlax-get-property objHTTP "ResponseText")
               (vlax-release-object objHTTP)
               (if (not (vl-catch-all-error-p Result))
                   Result
;;;(vk_GetRemoteText "http://www.opendcl.com/version/version.txt")
alanjt
  • Standby for witty remark...
« Reply #3 on: October 06, 2011, 01:21:55 PM »
wow  :kewl:
Dropbox
« Reply #4 on: October 06, 2011, 01:24:35 PM »
That is cool  8-)
« Reply #5 on: October 06, 2011, 01:27:49 PM »
Not sure if this applies to the WinHTTP Object, but here I found the XMLHTTP Object seemed to cache the result when using the "GET" keyword, so you may want to use the "POST" operator.
Lee
TopoWAR
« Reply #6 on: October 06, 2011, 02:14:17 PM »
by teachers, great code!! :lol:
Thanks for help
VovKa
  • Ukraine
« Reply #7 on: October 06, 2011, 05:01:27 PM »
i share with pleasure, thanks
Lee
i can't say anything for sure, know nothing about http
i've just googled this http://www.cs.tut.fi/~jkorpela/forms/methods.html
there is a paragraph about "caching" but as i've understood it's about cahing a request on a server not a local file
« Reply #8 on: October 06, 2011, 05:53:41 PM »
Lee
That's an interesting link, I shall have to take some time to read it more thoroughly.
I remember reading the following from here:
Quote from: MSDN
Internet Explorer caches the results of HTTP GET requests in the Temporary Internet Files (TIF) folder. In most cases, caching improves performance for data that will not change frequently. To guarantee that the results are not cached, use POST.
I noticed this caching when testing my Internet Time function, so thought I'd make you aware of the possibility.
At least, if a similar issue arises in the future you will know what to do :-)
Harrie
« Reply #9 on: October 07, 2011, 04:53:21 AM »
thanks
I know there was a topic to download the BBC news and the BCC weather forecast into the drawing,
but I can’t find it.
Lee your Internet Time function, is this giving the current internet date and time?
« Last Edit: October 07, 2011, 07:38:55 AM by Harrie »
« Reply #10 on: October 07, 2011, 07:09:03 AM »
thanks
http://www.theswamp.org/index.php?topic=37107
TopoWAR
« Reply #11 on: October 07, 2011, 10:15:58 AM »
code only works for text files, is this true ?
Is there some code that works for example with jpg or rar ?
Thanks for help
« Reply #12 on: October 07, 2011, 10:25:03 AM »
See my earlier links above.
VovKa
  • Ukraine
« Reply #13 on: October 07, 2011, 12:22:54 PM »
true, what do you expect from function named "vk_GetRemoteText"? :)
Harrie
« Reply #14 on: October 09, 2011, 03:53:29 PM »
thanks
Thanks Lee,
Your Internet Time function, is this giving the current internet date and time?
