Author Topic: VB.Net method of selecting by fence and/or window  (Read 2986 times)
cannorth
« on: October 05, 2011, 04:10:47 PM »
Hello,
   Is there a VB.Net method of selecting entities on screen using fence or window.  I'm looking for a single method rather than two separate ones.
Thanks,
cannorth
huiz
  • Certified Prof C3D
Re: VB.Net method of selecting by fence and/or window
« Reply #1 on: October 06, 2011, 02:34:06 AM »
When selecting on the screen people can use selection options like F or CP by themself. You can put that information in the PromptSelectionOptions.MessageForAdding.
fixo
« Reply #2 on: October 06, 2011, 04:59:14 AM »
Hello,
Thanks,
cannorth
Change to your suit, this one is from working project,
don't remember how it works :)
        #region "Selection with using of keywords"
        [CommandMethod("SelectBy")]
        public void GetSelectionWithKeywords()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            try
                   PromptKeywordOptions pko =
                       new PromptKeywordOptions( "\nChoose a selection method " + "[Window/Fence]: ",  "Window Fence"   );
            pko.Keywords.Default ="Window";
            PromptResult prk = ed.GetKeywords(pko);
            if (prk.Status != PromptStatus.OK)
                return;
                string kwd = prk.StringResult;
            PromptSelectionOptions pso = new PromptSelectionOptions();
                pso.MessageForAdding = "\nSelect objects by " + kwd + " selection";
                pso.MessageForRemoval =   "\nNothing selected, try again...";
                if (kwd == "Window")
                    PromptPointOptions ppo = new PromptPointOptions("\nSpecify a first corner: ");
                    PromptPointResult ppr = ed.GetPoint(ppo);
                    if (ppr.Status != PromptStatus.OK) return;
                    PromptCornerOptions pco = new PromptCornerOptions("\nOther corner: ", ppr.Value);
                    PromptPointResult pcr = ed.GetCorner(pco);
                    if (pcr.Status != PromptStatus.OK) return;
                    Point3d p1 = ppr.Value;
                    Point3d p2 = pcr.Value;
                    if (p1.X == p2.X || p1.Y == p2.Y)
                        ed.WriteMessage("\nInvalid coordinate specification");
                        return;
                    PromptSelectionResult psr= ed.SelectWindow(p1, p2);
                    if (psr.Status == PromptStatus.OK)
                        ed.WriteMessage("\n{0} object{1} selected.",  psr.Value.Count, psr.Value.Count == 1 ? "" : "s"  );
                if (kwd == "Fence")
                    PromptPointOptions ppo = new PromptPointOptions("\nSpecify a first fence point: ");
                    PromptPointOptions pco = new PromptPointOptions("\nSecond point: ");
                    pco.UseBasePoint = true;
                    pco.BasePoint = p1;
                    pco.UseDashedLine = true;
                    PromptPointResult pcr = ed.GetPoint(pco);
                    if (p1.X == p2.X && p1.Y == p2.Y)
                        return;
                    Point3dCollection points = new Point3dCollection();
                    points.Add(p1);
                    points.Add(p2);
                    PromptSelectionResult psr= ed.SelectFence(points);
                        ed.WriteMessage(   "\n{0} object{1} selected.",   psr.Value.Count, psr.Value.Count == 1 ? "" : "s"  );
            catch (System.Exception ex)
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + "\n" + ex.StackTrace);
            finally
        #endregion
To convert, try this:
http://converter.telerik.com/
~'J'~
