Author Topic: Rename directory with vlisp?  (Read 6137 times)
laidbacklarry
« on: October 04, 2011, 11:37:20 AM »
I know this can be done with dos_rendir from doslib, but we'd like to port all doslib functions (that we use) to lisp. This  is the only one we're stuck on... Thanks for any help
Re: Rename directory with vlisp?
« Reply #1 on: October 04, 2011, 11:39:57 AM »
vl-file-rename
« Reply #2 on: October 04, 2011, 11:45:04 AM »
e.g.
(vl-file-rename "c:\\docs\\rtfm" "c:\\docs\\lol-ok")
laidbacklarry
« Reply #3 on: October 04, 2011, 11:51:18 AM »
Thanks, guys...
alanjt
  • Standby for witty remark...
« Reply #4 on: October 04, 2011, 12:47:59 PM »
e.g.
  :-D
Dropbox
  • Custom Title
« Reply #5 on: October 04, 2011, 02:03:56 PM »
If you do a search HERE you come up empty if you search for vl-file-rename *shrug*
alanjt
« Reply #6 on: October 04, 2011, 02:05:53 PM »
vl-file-rename
Renames a file
(vl-file-rename old-filename new-filename)Arguments
old-filename
A string containing the name of the file you want to rename. If you do not specify a full path name, vl-file-rename looks in the AutoCAD default drawing directory.
new-filename
A string containing the new name to be assigned to the file.
NoteIf you do not specify a path name, vl-file-rename writes the renamed file to the AutoCAD default drawing directory.
Return Values
T, if renaming completed successfully; nil if renaming failed.
Examples
_$ (vl-file-rename "c:/newauto.bat"
"c:/myauto.bat")TNoteIf the target file already exists, this function fails.
Please send us your comments about this page
Dropbox
« Reply #7 on: October 04, 2011, 02:16:45 PM »
  • Custom Title
« Reply #8 on: October 04, 2011, 03:01:21 PM »
So RTFM would have been absolutely useless to the OP.
« Reply #9 on: October 04, 2011, 04:18:18 PM »
The rtfm was offered purely for levity, hope it was taken same. Unfortunately Autodesk authors their help much like the Microsoft docs, insomuch as sometimes things are implied or just left out. For example the MoveFolder method of the File System Object can be used to rename a folder but the docs don't reveal that. Chocolate chips cookies for every one in the thread.
alanjt
« Reply #10 on: October 04, 2011, 04:20:53 PM »
What's that, you were able to do something with a command that isn't document? Yeah, that's just an undocumented feature we didn't think you plebeians would care to know about.
Dropbox
jaydee
« Reply #11 on: October 04, 2011, 04:39:16 PM »
Something else u might want to consider
http://www.bulkrenameutility.co.uk/Screenshots.php
« Reply #12 on: October 04, 2011, 04:46:38 PM »
No hate, but not sure how this:
will help the OP pen alternates for doslib functions.
On another note, that interface gave me an aneurysm. :doa:
  • Custom Title
« Reply #13 on: October 04, 2011, 05:07:57 PM »
Then I apologize, I took offense to it.
OK, I'll leave now ... *grin*
« Reply #14 on: October 04, 2011, 05:11:09 PM »
My fault, I don't know the audience anymore, so the apologies are mine to make; sorry all.
Maverick®
« Reply #15 on: October 04, 2011, 05:38:24 PM »
Accepted.  *skips off humming Queen's "Bicycle"*
« Reply #16 on: October 04, 2011, 05:48:08 PM »
*takes long bong hit*
"I love you man".
irneb
« Reply #17 on: October 05, 2011, 02:33:16 AM »
:lmao:
The one I use is makes me "slightly" less nauseas.  ;)
Though not "strictly" part of this thread, I generally use it to rename those DWF/PDF files I generate from publish. I love the Preview idea to see the changes before you actually perform them, makes for less mistakes.
