Author Topic: [challenge]avoid 2 collision convex-polygon in any angle .  (Read 7753 times)
chlh_jd
Re: [challenge]avoid 2 collision convex-polygon in any angle .
« Reply #15 on: September 16, 2011, 01:42:23 AM »
Great solution Chen !
Thank you Lee for nice 'Test !
chlh_jd
« Reply #16 on: September 16, 2011, 02:36:28 AM »
In my codes in 6th-F, I use the method 'Move back from infinity' , it can be use all polygons but contains-arcs ; It alos can be use in move 2nd polygon from distant location to 1st polygon and they are not collided .
« Last Edit: September 16, 2011, 02:50:56 AM by chlh_jd »
chlh_jd
« Reply #17 on: September 16, 2011, 11:50:10 AM »
If the 2 polygons is not collided ,  Using Chen's method and my way will get deffrent results .
See the following picture .
« Reply #18 on: September 17, 2011, 09:07:24 AM »
Thanks Lee, I am very glad that you like this algorithm~~.
And I like your concise code and beautiful code style (Evgeniy use the same style~, it make me feel dizzy, but I like it very much).
Thanks Chen :-)  This code style is maybe a little obfuscated for main-stream applications which will need to be maintained, but I enjoy using it for these challenges  :-)
The 2nd LM's code make me feel dizziness ^^. But i think the 1st code can be improved to use with more Objects type  :)
Thanks guys  8-)
well20152016
« Reply #19 on: November 24, 2016, 05:19:32 AM »
Have bug?Hope can better improve。
« Last Edit: November 24, 2016, 05:44:13 AM by well20152016 »
ribarm
  • Marko Ribar, architect
« Reply #20 on: November 24, 2016, 10:41:41 AM »
Not 100% sure, but try this...
(defun c:MM ( / lw1 lw2 lst1 lst2 a rayintpolygon rtn lstm bb d )
  (setq lw1 (car (entsel "\nPick first POLYGON...")))
  (setq lw2 (car (entsel "\nPick second POLYGON which is about to move to first one...")))
  (setq lst1 (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= (car x) 10)) (entget lw1))))
  (setq lst2 (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= (car x) 10)) (entget lw2))))
  (setq a (getangle "\nPick or specify angle : "))
  (defun rayintpolygon ( p a lst / ip rtn )
    (foreach li (mapcar '(lambda ( a b ) (list a b)) lst (cdr (reverse (cons (car lst) (reverse lst)))))
      (if (setq ip (inters p (polar p a 1e+20) (car li) (cadr li)))
        (setq rtn (cons (list (mapcar '+ '(0 0) ip) (distance ip p)) rtn))
          ( (equal a (angle p (car li)) 1e-6)
            (setq rtn (cons (list (car li) (distance (car li) p)) rtn))
          ( (equal a (angle p (cadr li)) 1e-6)
            (setq rtn (cons (list (cadr li) (distance (cadr li) p)) rtn))
    rtn
  (foreach p lst2
    (setq rtn (append (rayintpolygon p a lst1) rtn))
  (foreach p lst1
    (setq rtn (append (rayintpolygon p (+ a pi) lst2) rtn))
  (foreach r (vl-sort rtn '(lambda ( a b ) (> (cadr a) (cadr b))))
    (setq lstm (cons (mapcar '(lambda ( p ) (polar p a (cadr r))) lst2) lstm))
  (foreach lst lstm
      (if (vl-some '(lambda ( li1 / ip ) (and (setq ip (inters (car li) (cadr li) (car li1) (cadr li1))) (setq ip (mapcar '+ '(0 0) ip)) (not (or (equal ip (car li) 1e-6) (equal ip (cadr li) 1e-6) (equal ip (car li1) 1e-6) (equal ip (cadr li1) 1e-6))))) (mapcar '(lambda ( a b ) (list a b)) lst1 (cdr (reverse (cons (car lst1) (reverse lst1))))))
        (setq lstm (vl-remove lst lstm))
  (defun bb ( lst / minp maxp )
    (setq minp (apply 'mapcar (cons 'min lst)))
    (setq maxp (apply 'mapcar (cons 'max lst)))
    (* (abs (- (car maxp) (car minp))) (abs (- (cadr maxp) (cadr minp))))
  (setq lstm (vl-sort lstm '(lambda ( a b ) (< (bb (append a lst1)) (bb (append b lst1))))))
  (setq d (distance (car lst2) (caar lstm)))
  (vla-move (vlax-ename->vla-object lw2) (vlax-3d-point '(0 0)) (vlax-3d-point (polar '(0 0) a d)))
M.R.
« Last Edit: November 24, 2016, 12:12:07 PM by ribarm »
M.R. on Youtube
