Hi.
I am using a rotate routine that currently handles blocks and mtext. I don't want to display the original block or mtext rotation when I the jig is dragging the clone.
It works that way but only for the blockreference. It's the same code but jigging mtext is shows the original as well as the rotating clone.
Can anyone suggest a correction to make? I've tried setting the entity visibility to false but the jig entity is also then hidden. Hope someone can help. Attached is the sampler and new jig parts.
Public Sub RotateEntity(ByVal objID As ObjectId, ByVal sPrompt As String)
Dim rotationPoint As Point3d
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim docLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
Dim trans As Transaction = db.TransactionManager.StartTransaction
Try
Dim ent As Entity = trans.GetObject(objID, OpenMode.ForRead)
If TypeOf ent Is BlockReference Then
Dim br As BlockReference = DirectCast(trans.GetObject(objID, OpenMode.ForRead), BlockReference)
rotationPoint = br.Position
ElseIf TypeOf ent Is MText Then
Dim mt As MText = DirectCast(trans.GetObject(objID, OpenMode.ForWrite), MText)
rotationPoint = mt.Location
End If
Dim baseAngle As Double = 0 'GetStoredRotation(obj)
If ent IsNot Nothing Then
Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem ' Get the current UCS, to pass to the Jig
Dim jig As New RotateJig(ent, rotationPoint, baseAngle, ucs) ' Create our jig object
'ent.UpgradeOpen()
'ent.Visible = False
'jig.GetEntity().Visible = True
Dim res As PromptResult = ed.Drag(jig)
If res.Status = PromptStatus.OK Then
Dim newAngle As Double = angle 'jig.GetRotation() ' Get the overall rotation angle and dispose of the temp clone
Rotation = angle 'this is just to put the angle into our globally used variable
ed.WriteMessage(newAngle)
jig.GetEntity().Dispose()
Dim transf As Matrix3d = Matrix3d.Rotation(newAngle - baseAngle, ucs.CoordinateSystem3d.Zaxis, rotationPoint) ' Rotate the original entity
ent.UpgradeOpen()
ent.TransformBy(transf)
End If
End If
trans.Commit() : trans.Dispose()
Catch ex As Autodesk.AutoCAD.Runtime.Exception
MsgBox("Exception:" + ex.Message)
trans.Abort() : trans.Dispose()
Finally
docLock.Dispose()
End Try
End Sub
