Author Topic: Xref to Overlay/Attach  (Read 4126 times)
cmwade77
« on: August 17, 2011, 04:28:28 PM »
Ok, thanks to the help of those on this board, I have my first pass at my new version of this routine. The command will convert all xrefs to overlay or attach as applicable. I would like input on this command and what might be able to be done to make it faster or even more stable. I previously had a version of this routine that someone else started and I fixed, but it did not always work correctly and had some problems with crashing. As a result, I have completely rewritten it myself using what I have learned since working on that routine, much of which I have learned from the people on the swamp.
Edit 03/03/2013 to update the code:
; Xref to Attach/Overlay **
; Written by: Chris Wade **
;     Version 2.1a  **
; 12/07/2011   **
; - Adjusted code to temporarily disable all reactors to prevent interference with LISP routine. **
;     Version 2.1   **
; 12/05/2011   **
; - Changes that attachment type for all XRefs.   **
;     - X2A - Changes all xrefs to attached method.   **
;   - X2O - Changes all xrefs to overlay method.   **
; - Known Limitations:                     **
;     - Viewport specific layer overrides may not be restored. **
(defun C:x2a ()
(xmethodflip "a")
(defun C:x2o ()
(xmethodflip "o")
(defun xmethodflip (mode / *ACAD_DOC* *PaperSpace* *ModelSpace* *Active* *ActiveID* allReactors cLayout BlockDef xObj2 SS2 LS Temp Clip ClipLength ClipCount ClipTemp Clip1 Clip2 xIsClipped XNameList BlockCollection xInsPt xLayer xScaleX xScaleY xScaleZ xRotation xPath Obj2 xObj xObjName xLayout xOwnerID); Mode - O = Overlay / A = Attach
(setvar "cmdecho" 0)
(setq *ACAD_DOC* (vla-get-ActiveDocument (vlax-get-acad-object))
  *PaperSpace* (vla-get-paperspace *ACAD_DOC*)
  *ModelSpace* (vla-get-modelspace *ACAD_DOC*)
((or (= (getvar "tilemode") 1) (/= (getvar "cvport") 1))
(setq xLayout *ModelSpace*)
((and (= (getvar "tilemode") 0) (= (getvar "cvport") 1))
(setq xLayout *PaperSpace*)
;Supporting Functions
(defun x2a_NotNested (name / SS)
(setq ss (ssget "_X" (list (cons 2 name) (cons 410 (getvar "ctab"))))
SS
(defun x2a_r2d (rad /)
(/ (* rad 180) pi)
(defun x2a_GetXclip ( ename / __XClipBoundary elist xlist _xang _xnor ); Code from Lee Mac @ http://www.theswamp.org/index.php?topic=39201.msg444239#msg444239
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix Transpose - Doug Wilson
(defun trp ( m ) (apply 'mapcar (cons 'list m)))
(defun __XClipBoundary ( ename / xdict )
(setq xdict (cdr (assoc 360 (entget ename))))
(__XClipBoundary xdict)
(and
(eq "SPATIAL_FILTER" (cdr (assoc 0 (setq ename (entget ename)))))
(eq 1 (cdr (assoc 71 ename)))
(lambda ( massoc ) (massoc 10 ename))
(lambda ( key elist / item )
(if (setq item (assoc key elist))
(cons (cdr item) (massoc key (cdr (member item elist))))
(defun __dxf ( key lst ) (cdr (assoc key lst)))
(setq elist (entget ename)
  _xang (__dxf  50 elist)
  _xnor (__dxf 210 elist)
(if (setq xlist (__XClipBoundary ename))
(lambda ( matrix )
(lambda ( vector )
(mapcar
(function
(lambda ( point )
(mapcar '+ (mxv matrix point) vector)
xlist
(mapcar '- (trans (__dxf 10 elist) _xnor 0)
(mxv matrix
(__dxf 10 (tblsearch "BLOCK" (__dxf 2 elist)))
(mxm
(mapcar
(function
(lambda ( v ) (trans v 0 _xnor t))
(1.0 0.0 0.0)
(0.0 1.0 0.0)
(0.0 0.0 1.0)
(mxm
(list
(list (cos _xang) (sin (- _xang)) 0.0)
(list (sin _xang) (cos _xang)     0.0)
(list 0.0         0.0             1.0)
(list
(list (__dxf 41 elist) 0.0 0.0)
(list 0.0 (__dxf 42 elist) 0.0)
(list 0.0 0.0 (__dxf 43 elist))
;;  by CAB 10/05/2007
  ;;  Expects pts to be a list of 2D or 3D points
  ;;  Returns new pline object
  (defun x2a_makePline (spc pts)
;;  flatten the point list to 2d
(if (= (length (car pts)) 2) ; 2d point list
  (setq pts (apply 'append pts))
  (setq pts (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) pts)))
(setq
  pts (vlax-make-variant
(vlax-safearray-fill
  (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pts))))
  pts
(vla-addlightweightpolyline spc pts)
;Code to determine if layerstate is present provided by AlanJT
(defun x2a_isLayerStatePresent (doc layerstate / state)
  (if (not
(vl-catch-all-error-p
  (vl-catch-all-apply
'(lambda (/)
   (setq state (vla-item (vla-item (vla-GetExtensionDictionary (vla-get-layers doc))
   "ACAD_LAYERSTATES"
layerstate
state
;End of Supporting Functions
(vla-StartUndoMark *ACAD_DOC*)
(setq allReactors (apply 'append (mapcar 'cdr (vlr-reactors))))
(if allReactors (mapcar 'vlr-remove allReactors)) ; temporarily disable all reactors - Code by roy_043 @ http://www.theswamp.org/index.php?topic=34597.msg408535#msg408535
(setq cLayout (vla-get-activelayout *ACAD_DOC*))
(vlax-for L (vla-get-layouts *ACAD_DOC*)
(vla-put-activelayout *ACAD_DOC* L)
(setq SS (ssget "_X" (list '(0 . "INSERT") (cons 410 (getvar "ctab")))))
(SS
(setq LS 1
  BlockCollection (vla-get-blocks *ACAD_DOC*)
(while (x2a_isLayerStatePresent *ACAD_DOC* (strcat "X2A-" (rtos LS 2 0)))
(setq LS (+ LS 1))
(vl-cmdf "._-layer" "_a" "_save" (strcat "X2A-" (rtos LS 2 0)) "" "" "")
((lambda (i / Ent)
(while (setq Ent (ssname SS (setq i (1+ i))))
(setq xObj2 (vlax-ename->vla-object Ent))
(xObj2
(setq BlockDef (vla-item BlockCollection (vla-get-name xObj2)))
((= (vla-get-isxref BlockDef) :vlax-true)
(setq xRname (vla-get-name xObj2)
  xPath (vla-get-path BlockDef)
  SS2 (x2a_NotNested xRname)
((Lambda (I2 / Ent2)
(While (Setq Ent2 (Ssname Ss2 (Setq I2 (1+ I2))))
(Setq Xobj (Vlax-ename->vla-object Ent2)
  Xinspt (Cons (Vlax-safearray->list (Variant-value (Vla-get-insertionpoint Xobj))) Xinspt)
  Xownerid (Cons (Vla-get-ownerid Xobj) Xownerid)
  Xscalex (Cons (Vla-get-xscalefactor Xobj) Xscalex)
  Xscaley (Cons (Vla-get-yscalefactor Xobj) Xscaley)
  Xscalez (Cons (Vla-get-zscalefactor Xobj) Xscalez)
  Xrotation (Cons (Vla-get-rotation Xobj) Xrotation)
  Xlayer (Cons (Vla-get-layer Xobj) Xlayer)
  Xisclipped (Cons (X2a_getxclip (Vlax-vla-object->ename Xobj)) Xisclipped)
-1)
(vla-detach BlockDef)
((Lambda (Ct2 / Ent2)
(While (Setq Ent2 (Ssname Ss2 (Setq Ct2 (1+ Ct2))))
((or (< (nth Ct2 xScaleX) 0) (< (nth Ct2 xScaleY) 0) (< (nth Ct2 xScaleZ) 0)); This is put here for xRefs that have been mirrored.
(vl-cmdf "._-xref" (strcat "_" mode) xPath (nth Ct2 xInsPt)(nth Ct2 xScaleX) (nth Ct2 xScaleY) (x2a_r2d (nth Ct2 xRotation)))
(setq Obj2 (vlax-ename->vla-object (entlast)))
(T
((= (strcase mode) "O")
(setq Obj2 (vla-attachexternalreference xLayout xPath (vl-filename-base xPath) (vlax-3D-point (nth Ct2 xInsPt)) (nth Ct2 xScaleX) (nth Ct2 xScaleY) (nth Ct2 xScaleZ) (nth Ct2 xRotation) :vlax-true))
((= (strcase mode) "A")
(setq Obj2 (vla-attachexternalreference xLayout xPath (vl-filename-base xPath) (vlax-3D-point (nth Ct2 xInsPt)) (nth Ct2 xScaleX) (nth Ct2 xScaleY) (nth Ct2 xScaleZ) (nth Ct2 xRotation) :vlax-false))
(vla-put-layer Obj2 (nth Ct2 xLayer))
((nth Ct2 xIsClipped)
(setq Clip (nth Ct2 xIsClipped)
  ClipLength (length Clip)
  ClipCount 0
((= ClipLength 2)
(setq Clip1 (nth 0 Clip)
  Clip2 (nth 1 Clip)
  Clip (list Clip1 (list (car Clip2) (cadr Clip1) (caddr Clip1)) Clip2 (list (car Clip1) (cadr Clip2) (caddr Clip2)))
(setq Clip (x2a_MakePline xLayout Clip))
((/= (vla-get-closed Clip) T)
(vla-put-closed Clip T)
(vl-cmdf "._xclip" (vlax-vla-object->ename Obj2) "" "_N" "_S" (entlast))
(vla-delete Clip)
-1)
-1)
(command "._-layer" "a" "restore" (strcat "X2A-" (rtos LS 2 0)) "" "")
(command "._-layer" "a" "delete" (strcat "X2A-" (rtos LS 2 0)) "" "")
(vla-put-activelayout *ACAD_DOC* cLayout)
(if allReactors (mapcar 'vlr-add allReactors)); Restores Reactors
(vla-EndUndoMark *ACAD_DOC*)
« Last Edit: April 03, 2013, 01:55:28 PM by cmwade77 »
airportman
  • i customize when required
Re: Xref to Overlay/Attach
« Reply #1 on: April 03, 2013, 01:17:46 PM »
when I load this in the VLIDE and run a
check edit... i get 2 warnings
local variable used as a function: MASSOC
local variable used as a function: __XCLIPBOUNDARY
do i need to declare them somewhere else to resolve this issue?
Perception is a state of mind  -/ Twitter = @hochanz -/ Intel i7 - 3.07GHz -/ 12GB Ram -/ Nvidia Quadro FX 1800
cmwade77
« Reply #2 on: April 03, 2013, 01:50:17 PM »
This routine is extremely complex and these warning are expected but do not prevent the routine from running. That being said, I did notice that the code was out of date and I have updated it in the original post with some bug fixes.
Please note that this will only run on the Windows version of AutoCAD and that this routine is not necessary in the 2014 version of AutoCAD, as you can now change the attachment type for multiple xRefs in the xRef tool palette.
