Uhm, first would you please use code tags to surround you code. In the post editor there's a button with a hash (#) which will insert such for you.
Next, you're using entmake to create the INSERT. The ATTRIB needs to follow that, and finally you need to create a SEQEND to stop. It's much simpler just inserting the block using command, or even just through vla.
