Sorry Krushert, What do you mean by callout line? leaders, elevation callout, section callout?
Is there such a beast?And if so, could someone post a sample so I can test it to see if it will work in our application?
Dynamic Block will be the best solution to this...as the section line length will most always be a variable with NO respect to viewport scale. As it will be determined by the object being sectioned, not the scale the section is viewed at.
Quote from: Higgs Boson's Mate on August 10, 2011, 02:38:14 PMDynamic Block will be the best solution to this...as the section line length will most always be a variable with NO respect to viewport scale. As it will be determined by the object being sectioned, not the scale the section is viewed at.Dynamic block will not work in this application because these section call out will show up at different scales. The reason is that the callout is for a full height building section of a multi-floor building and it needs to show up in the overall floor plan(s) and the enlarged plans for each floor. Capisci?
But can a dynamic stretch have different values for the different canno scales?Разве я не понимаю динамическое действие протяжения блока правильно? вы не понимаете этого?
