Author Topic: Metric thread  (Read 2818 times)
Atwist
Metric thread
« on: August 06, 2011, 09:50:02 AM »
Hello Everyone
Does anyone have a lisp for Metric thread.
I can not find anything with google, so I try it here.
Tharwat
  • Hypersensitive
Re: Metric thread
« Reply #1 on: August 06, 2011, 11:15:30 AM »
Hi .
What do you mean by Metric Thread ?
Could you please explain a little bit further ?
Atwist
Re: Metric thread
« Reply #2 on: August 06, 2011, 11:19:15 AM »
As wire hole top and side view
for  screw, bolt
Drill hole
HofCAD
Re: Metric thread
« Reply #3 on: August 06, 2011, 01:54:02 PM »
Hello Everyone
Dear Atwist,
This is not a very different question then your question about 'Metric tread hole'
in  http://www.theswamp.org/index.php?topic=37127.msg421732#msg421732
There and in http://www.cadsite.be/smf/index.php?topic=4647.0 you could
find a solution for Metric Screw Thread holes with Tap.lsp and TapE.lsp.
You would like also to draw the screw and the bolt in it.
You didn’t see the message there from Andrew_nao with Fast.zip?
You can also start with: http://www.draftsperson.net/index.php?title=Draw_Bolts_-_Free_LISP
Regards, HofCAD CSI.
« Last Edit: August 06, 2011, 06:10:28 PM by HofCAD »
Re: Metric thread
« Reply #4 on: August 07, 2011, 08:22:51 AM »
Odd, I can't open the BOLTS.zip file in the last link.
Says invalid file format, using Jzip to open it.
HofCAD
Re: Metric thread
« Reply #5 on: August 07, 2011, 09:11:43 AM »
Dear CAD,
I did try it again and I found no problem.
Dowload the BOLTS.zip
Save
Open with jZip.exe
Regards HofCAD CSI.
delium55
Re: Metric thread
« Reply #6 on: August 07, 2011, 10:58:59 AM »
Look at Afralisp.net/download and you will find "Metrics fasteners"
http://www.caderix.com/crbst_2.html and upload  "Les vis dynamiques"
If that can help.  :-D
Re: Metric thread
« Reply #7 on: August 07, 2011, 11:26:10 AM »
HofCAD,
Downloaded it again and unzipped fine.
Atwist
Re: Metric thread
« Reply #8 on: August 07, 2011, 11:40:54 AM »
Hi everyone,
Thank you very much you have me back on track.
I can get on with my tools.
