Author Topic: Need help with macro for 3 point arc  (Read 5734 times)
TJAM51
« on: February 03, 2005, 03:10:26 PM »
I need to draw a 3 point arc but I need to have the osmode set to nearest for the first point, the osmode set to zero for the second point and the osmode set back to nearest (512) for the third and last point......I know it possibly can be doen but how......
« Reply #1 on: February 03, 2005, 03:57:14 PM »
will something like this work?
(defun c:a3 (/ osm p1 p2 p3)
  (setq osm (getvar 'osmode))
  (setvar 'osmode 0)
  (if (setq p1 (osnap (getpoint "\nPoint 1: ") "_near"))
    (if (setq p2 (osnap (getpoint p1 "\nPoint 2: ") "_none"))
      (if (setq p3 (osnap (getpoint p2 "\nPoint 3: ") "_near"))
(vl-cmdf "_arc" p1 p2 p3)
  (setvar 'osmode osm)
TJAM51
« Reply #2 on: February 03, 2005, 03:59:57 PM »
Neat routine but I was hoping not to type in but simply pick the locations.
« Reply #3 on: February 03, 2005, 04:01:11 PM »
type in what?
« Reply #4 on: February 03, 2005, 04:05:08 PM »
Here is another one:
(defun c:3arc (/ osm)
  (setvar 'osmode 0)
  (command ".arc" "_near" pause "_none" pause "_near" pause)
TJAM51
« Reply #5 on: February 03, 2005, 04:05:18 PM »
I had to type in "NEAR" when it prompted me for point 1.
TJAM51
« Reply #6 on: February 03, 2005, 04:06:49 PM »
:oops: I see now I realize now it did work.......thanks much....
VerticalMojo
« Reply #7 on: February 03, 2005, 04:32:49 PM »
Without LISP
osmode;0;_arc near;\_c;\near;\
« Reply #8 on: February 03, 2005, 05:41:43 PM »
Quote from: ronjonp
  (setvar 'osmode 0)
When you use the osmode override you don't need to set osmode to 0
(defun c:3arc ()
« Reply #9 on: February 03, 2005, 05:48:02 PM »
Quote from: VerticalMojo
Without LISP
That is a good one, here without _c
^C^C_arc _near;\_non;\_near;\
t-bear
« Reply #10 on: February 03, 2005, 06:35:23 PM »
Man, you guys are havin' too much fun!  This stuff is cool!
TJAM51
« Reply #11 on: February 04, 2005, 08:57:45 AM »
Here would be a different type of 3 point arc.....first point and second point and the drag in the desired direction....here is a macr of a similar situation...how could this be put to lisp?
arc;node,quad;\$M=E;node,quad;\;$(getvar,lastpoint);
« Reply #12 on: February 04, 2005, 09:41:44 AM »
Are you trying to do this? [macro]
^C^C_arc \e;\d;
TJAM51
« Reply #13 on: February 04, 2005, 10:00:02 AM »
How could this be put to lisp?
« Reply #14 on: February 04, 2005, 10:15:53 AM »
(command "._arc" pause "_e" pause "_d" pause)
