Author Topic: how to use netload while my filedia is equal to zero  (Read 1911 times)
Coder
« on: June 28, 2011, 04:10:36 AM »
Hello everybody  .
Suppose that my system variable is equal to zero and I want to use a lisp to load a .dll file , what should I write for the command netload to load the required
file through lisp routine ?
Man thanks .
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: how to use netload while my filedia is equal to zero
« Reply #1 on: June 28, 2011, 06:29:53 AM »
hint:
(setvar "FILEDIA" 1)
Called Kerry in my other life
I live at UTC + 13.00
Coder
« Reply #2 on: June 28, 2011, 07:06:32 AM »
Thanks .
I do know that , but I want to load a .dll program by Lisp .
kdub_nz
  • SuperMod
« Reply #3 on: June 28, 2011, 07:45:45 AM »
Do you know the name and location of the file that you want to load from your lisp file ?
Coder
« Reply #4 on: June 28, 2011, 08:05:34 AM »
Yes of course .  :-)
the location is in my Cad support folder .
"C:\Program Files\AutoCAD 2010\Support"
And I know the program name to include within the lisp routine
Thanks for your interests .
kdub_nz
  • SuperMod
« Reply #5 on: June 28, 2011, 08:11:33 AM »
(command "NETLOAD" "C:\\Program Files\\AutoCAD 2010\\Support\\Stuff.dll")
may work, subject to operating system permissions.
kdub_nz
  • SuperMod
« Reply #6 on: June 28, 2011, 08:18:08 AM »
or something like :-
(if (Setq fileToLoad
           (getfiled "Select a DLL File"
                     "c:/kdub_SteelTools/Support/"
                     "dll"
                     8
  (command "NETLOAD" fileToLoad)
  ;; else
  (alert "OOppppss")
« Last Edit: June 28, 2011, 08:24:53 AM by kdub_bne »
Coder
« Reply #7 on: June 28, 2011, 08:56:54 AM »
Thank you so much , I may try it today and would let you know .
Appreciated a lot .  :-)
