Author Topic: Area calculation with reactor objects  (Read 2245 times)
vinnypoon
« on: January 31, 2005, 05:22:59 PM »
I found a nice VLISP area calculation tool last week called areacalc.vlx. The area text info is a reactor object so it update dynamically as the associated polyline changes. The only problem is that the area is in square inches not sq.ft.. Does anyone use a similar function but in sq.ft.? Thanks
Anonymous
« Reply #1 on: January 31, 2005, 08:29:52 PM »
Try KozMos LabelRoom2005 at http://www.ikozmos.com/htmls/labelroom2005.htm
You can set the "Calc" and User Suffix to fit ur purpose.
