Author Topic: Convert Txt 2 Attribute  (Read 3851 times)
nyah
« on: June 01, 2011, 11:58:55 AM »
Hello Everyone
Need my fix of help:
Problem have dumb text above a valve and need it to be converted to an attribute and if poss srrounded by a rect box
Any ideas as is it an express tool option or anyone have the lisp routine. I thought about the action macro for the box am I way off?
Nyah
Re: Convert Txt 2 Attribute
« Reply #1 on: June 01, 2011, 12:07:25 PM »
Does this help?
;;-------------------=={ Text 2 Attribute }==-----------------;;
;;  Converts single-line text to an attribute definition.     ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
(defun c:txt2att ( / el i ss st ) (vl-load-com)
  (if (setq ss (ssget "_:L" '((0 . "TEXT"))))
    (repeat (setq i (sslength ss))
      (setq el (entget (ssname ss (setq i (1- i))))
            st (vl-string-translate " " "_" (cdr (assoc 1 el)))
        (entmakex
          (append '((0 . "ATTDEF"))
            (vl-remove-if '(lambda ( pair ) (member (car pair) '(0 100 73))) el)
            (list
              (cons 70  0)
              (cons 74 (cdr (assoc 73 el)))
              (cons  2 st)
              (cons  3 st)
        (entdel (cdr (assoc -1 el)))
As for the Rectangle, how about TCIRCLE from Express Tools  :-)
