Author Topic: dimensioning  (Read 2427 times)
NirantarVidyarthee
dimensioning
« on: May 12, 2011, 02:05:48 AM »
I create a line in modelspace and dimension it.
When I modify the length of the line, the dimension also gets modified accordingly.
However, I was under the impression that when I delete the line the dimension is also deleted. But, it seems, it does not.
Is this normal behavior or is there any sysvar associated with it.
Re: dimensioning
« Reply #1 on: May 12, 2011, 07:32:18 AM »
You describe what is known as an 'Associative Dimension' - the associativity is controlled by the DIMASSOC System Variable.
It is normal behaviour for the dimension to remain, and to my knowledge there isn't a setting or SystemVariable to enable its deletion.
Lee
