Author Topic: Missing Font and Shape File  (Read 3427 times)
GDF
« on: May 11, 2011, 10:43:33 AM »
Does anyone have a routine for changing all text that have a missing font and or shape file (.shx) to the default text style "Regular" with the default shape file (txt.shx)? I want to eliminate the popup dialog boxes......."Specify Font for Style..."
I get drawings from others outside the office that fail to include the missing font shape file.
I'm fishing without bait this morning.....
Re: Missing Font and Shape File
« Reply #1 on: May 11, 2011, 11:02:39 AM »
set fontalt
fontalt
Enter new value for FONTALT, or . for none <"simplex.shx">:
HasanCAD
« Reply #2 on: May 11, 2011, 11:46:47 AM »
I am facing the same problem and FONTALT didnot solve this problem still this window comes
« Reply #3 on: May 11, 2011, 11:53:57 AM »
do you have that set in your startup document?
and or what is your setting for FONTMAP>>>
Enter new value for FONTMAP, or . for none
<"C:\Users\Administrator\appdata\roaming\autodesk\c3d 2011\enu...">:
GDF
« Reply #4 on: May 11, 2011, 12:03:08 PM »
I placed this in my startup...and now I don't get those annoying pop ups.
(setvar "fontalt" "txt")
rkmcswain
« Reply #5 on: May 05, 2016, 08:46:05 AM »
That is because the "Select Shape File" dialog is asking you to select the SHAPE FILE that the drawing is referencing.
This is different than a FONT FILE.
Yes, they both share the .SHX file extension, but they are not interchangeable.
dgorsman
« Reply #6 on: May 05, 2016, 10:13:47 AM »
Not through the user interface, anyways.  I've had a couple of drawings come in which had some styles that couldn't be purged due to inappropriate shape file use.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
