Author Topic: Segment Labels Format  (Read 9403 times)
Re: Segment Labels Format
« Reply #15 on: May 05, 2011, 01:42:37 PM »
I just have a secondary style with the (P) suffix, but I'd love to know what Michael does.
I thought about that too but then you'd have to have all kinds of lines in your dwg. So far the best solution I can come up with is just editing the label and adding 100'(P).
why would you have to have all kinds of lines in your file?
you could have a label that was only (P)
linked to feature and then offset the usual distance...
« Reply #16 on: May 05, 2011, 01:57:56 PM »
how do you 'link to a feature?
thanks
alanjt
  • Standby for witty remark...
« Reply #17 on: May 05, 2011, 02:06:16 PM »
What do you mean by 'all kinds of lines in your dwg'? It's just a different style to which you can easily apply to certain line labels. You can do it through the right-click menu or use the LABELSTYLEEDIT command.
Dropbox
« Reply #18 on: May 05, 2011, 02:09:54 PM »
thanks
uh...you know...
on the LAYOUT TAB of the label style composer....
Achor Component <FEATURE>
Anchor Point
Settings
« Reply #19 on: May 05, 2011, 02:14:22 PM »
My labels have to shown as N89°45'32"W 451.25(M) 451.0(P). *shrug*
thanks
uh...you know...
Anchor Point
Settings
alanjt
« Reply #20 on: May 05, 2011, 02:16:14 PM »
thanks
uh...you know...
Anchor Point
Settings
Since it's a line to line change, I'd have to agree with your original idea that you would just have to edit them individually.
Dropbox
« Reply #21 on: May 05, 2011, 02:18:40 PM »
styles would still work for this....they would simply need REALLY good names.
alanjt
« Reply #22 on: May 05, 2011, 02:22:15 PM »
Yes, but he'd still have to edit each to plug in the PLAT distance since the linework reference by the label would be at a measured bearing/distance.
Dropbox
« Reply #23 on: May 05, 2011, 02:23:48 PM »
Well I would love to see a sample if you ever get the time to make one. :)
alanjt
« Reply #24 on: May 05, 2011, 02:24:17 PM »
x2
Dropbox
« Reply #25 on: May 05, 2011, 03:07:58 PM »
This is why I get heartburn when trying to use Labels.
« Reply #26 on: May 05, 2011, 03:11:57 PM »
uh, no...
because the PLAT parcel boundary is the one being labled
are you not stacking the survey data files?
SURVEY: this is what you found based on your calculations. Some prefer to place the calculated data in it's own file so that it and the found information never commingle.  Or be sure that ALL calculated data has really good descriptiors, I've had two recent experiences were calculated became accepted and the description wasn't changed.
PLAT: this file references the SURVEY from above.  This file contains the accepted plat lines.
The labels in this file can have wipeouts (background masks) in them to show or hide the record information if accepted. one the shows record distance, bearing, others can be added as needed for special cases.
It has this label style (R) applied to it with unique layer properties in the survey file.
These labels can then have a (P) plat style applied to them.
