Author Topic: Getting extra charcters when using RTOS  (Read 2295 times)
Krushert
  • FREE BEER Tomorrow!!
« on: April 12, 2011, 04:04:29 PM »
So I started with some of Kerry's code and then realizing it is spitting out in real numbers and I need to convert to string form.  When I tried to do it I am getting extra characters.  Why???  If I remove the rtos, it retuns the real number in the correct form.
"3'-3 1/4\" "
_$
it should read 3'-3 1/4"
(SETQ DimEnt2  (CAR (ENTSEL "\nSelect Height Dimension :") )
         DimObj2  (VLAX-ENAME->VLA-OBJECT DimEnt2)
         Measurement2 (rtos (VLAX-GET DimObj2 'Measurement) 4 6)
Re: Getting extra charcters when using RTOS
« Reply #1 on: April 12, 2011, 04:11:03 PM »
Try the two  :-) :
(alert "3'-3 1/4\"")
(alert "3'-3 1/4")
Krushert
« Reply #2 on: April 12, 2011, 04:19:31 PM »
Okay?  :|   That is weird.
But I can see that I did not take it far enough.  I was just looking at what was being returned in watch window thinking that was what I was going to get.
Thank you.
« Reply #3 on: April 12, 2011, 04:25:03 PM »
Thank you.
No prob  :-)
« Reply #4 on: April 12, 2011, 04:25:35 PM »
Ask yourself: How does one express a quotation mark in a string without signifying the end of the string itself?
The same applies to the backslash - consider the following:
(alert "a\tb")
(alert "a\\tb")
« Reply #5 on: April 12, 2011, 04:30:21 PM »
Or try (alert (chr 34))  :lol:
« Reply #6 on: April 12, 2011, 04:31:02 PM »
Krushert
« Reply #7 on: April 12, 2011, 04:34:45 PM »
Oooooohhhhhh.
Okay that explains it.  Thanks.
