Author Topic: How to determine if the next vertex in polyline is a bulge  (Read 2790 times)
huiz
  • Certified Prof C3D
« on: March 25, 2011, 03:31:06 AM »
If I have a loop through the vertex points of a polyline to extract a point3d, I get the endpoints of the vertices. But I also want the midpoint of bulges. What is the best way to get that point?
I thought: check to see if next vertex is a bulge, extract that vertex as an arc and get a point over a half distance.
But there might be simpeler solutions. Anyone?
gile
  • Marseille, France
Re: How to determine if the next vertex in polyline is a bulge
« Reply #1 on: March 25, 2011, 04:23:23 AM »
Look at the Curve.GetPointAtParameter() method.
For a polyline the parameter at each vertex is an integer (0.0, 1.0, 2.0, ...) so:
pline.GetPointAtParameter(0.5) returns the midpoint of the first segment of the pline (between vertex 0 and vertex 1),
pline.GetPointAtParameter(1.5) the mipoint of the second segment, and so on.
huiz
« Reply #2 on: March 25, 2011, 05:16:57 AM »
Thanks Gile, that sounds clear :-)
But I'll get also points in the middle of straight vertices I assume. Is it possible to check if a vertex is a bulge? Or do I have to check if (midpoint between GetPointOnPArameter(0) and GetPointOnPArameter(1)) != GetPointOnPArameter(0.5)?
Jeff H
« Reply #3 on: March 25, 2011, 05:28:07 AM »
Have a look at
Polyline.HasBulges
Assesses if the polyline has any bulge factors set for any of the segments. Bulge factor values are required for arc segments within the polyline.
Polyline.GetBulgeAt
This function gets the bulge factor value at the index vertex. The bulge factor is used to indicate how much of an arc segment is present at this vertex. The bulge factor is the tangent of one fourth the included angle for an arc segment, made negative if the arc goes clockwise from the start point to the endpoint. A bulge of 0 indicates a straight segment, and a bulge of 1 is a semicircle.
While looping check if 0
« Reply #4 on: March 25, 2011, 05:29:21 AM »
huiz
« Reply #5 on: March 25, 2011, 05:47:23 AM »
Wow! It is actually really simple :-) Thanks all!
« Reply #6 on: March 25, 2011, 06:33:40 AM »
It takes a lot of effort to make it look that simple :) Thanks gile.
huiz
« Reply #7 on: March 25, 2011, 07:34:09 AM »
Indeed. I already looked at the GetBulge option but didn't find out how it works. But the excellent code examples of Gile (and others) are very clear and instructive and now I am able to continue exploring, because now it looks simple :-)
I really do learn a lot from people like Gile and you Kerry, and many others. And probably we don't say "thank you" that much, but I am really grateful!
fixo
« Reply #8 on: March 25, 2011, 09:00:52 AM »
Deep inside the code see SegmentType:
        [CommandMethod("lotes")]
        public static void GenerateCoordTable()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                try
                    PromptEntityOptions peo = new PromptEntityOptions("\nSelect a boundary polygon >>");
                    peo.SetRejectMessage("\nSelect Polyline only >>");
                    peo.AddAllowedClass(typeof(Polyline), false);
                    PromptEntityResult res;
                    res = ed.GetEntity(peo);
                    if (res.Status != PromptStatus.OK)
                        return;
                    Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                    if (ent == null)
                        return;
                    Polyline poly = (Polyline)ent as Polyline;
                    if (poly == null)
                        return;
                    string lotno = UserInteraction.UserInput.GetStringDefault(ed, "\nEnter a lot number", "101");
                    int prec;
                    if (!(UserInteraction.UserInput.GetIntDefault(ed, "\nEnter number of decimals for table values: ", 1, out prec)))
                        ed.WriteMessage("\nNo value entered. Programm exiting");
                        return;
                    double hgt = UserInteraction.UserInput.GetRealDefault(ed, "\nEnter text height for data cells: ", 0.2);
                    List<string[]> arr = PointsToTable(poly, prec);
                    if (arr == null)
                        return;
                    Point3d position = new Point3d();
                    if (!(UserInteraction.UserInput.GetFirstPoint(ed, "Specify insertion point: ", out position)))
                        ed.WriteMessage("\nNo points picked. Programm exiting");
                        return;
                    //draw table
                    int nmRows = arr.Count + 2;
                    int nmColumns = arr[0].Length;
                    double rowHeight = hgt * 1.5;
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Table oTable = new Table();
                    oTable.IsHeaderSuppressed = false;
                    oTable.IsTitleSuppressed = false;
                    oTable.VerticalCellMargin = hgt * 0.1;
                    oTable.HorizontalCellMargin = hgt * 0.1;
                    oTable.NumColumns = nmColumns;
                    oTable.NumRows = nmRows;
                    oTable.Height = nmRows * hgt * 1.25;
                    oTable.Width = hgt * 76;
                    oTable.Position = position;
                    oTable.SuppressRegenerateTable(true);
                    oTable.GenerateLayout();
                    oTable.SetTextString(0, 0, "Lotes " + lotno.ToString());
                    SetCell(oTable, 0, 0, "Lotes " + lotno.ToString(), hgt * 2.0, CellAlignment.MiddleCenter);
                    oTable.SetColumnWidth(0, hgt * 16);
                    oTable.SetColumnWidth(1, hgt * 15);
                    oTable.SetColumnWidth(2, hgt * 15);
                    oTable.SetColumnWidth(3, hgt * 15);
                    oTable.SetColumnWidth(4, hgt * 15);
                    oTable.SetTextHeight(hgt * 2, (int)RowType.TitleRow);
                    oTable.SetTextHeight(hgt * 1.5, (int)RowType.HeaderRow);
                    oTable.SetTextHeight(hgt, (int)RowType.DataRow);
                    string[] hdl = new string[5];
                    hdl[0] = "Point No";
                    hdl[1] = "X";
                    hdl[2] = "Y";
                    hdl[3] = "Z";
                    hdl[4] = "Radius";
                    for (int i = 0; i < hdl.Length; i++)
                        string s = hdl[i];
                        SetCell(oTable, 1, i, s, hgt * 1.5, CellAlignment.MiddleCenter);
                    for (int i = 0; i < arr.Count; i++)
                        string[] line = arr[i];
                        for (int j = 0; j < hdl.Length; j++)
                            string s = line[j];
                            ed.WriteMessage("\n\t{0}\t{1}", i + 2, j);
                            if (s != "")
                                SetCell(oTable, i + 2, j, s, hgt,
                                    j == 0 ? CellAlignment.MiddleLeft : CellAlignment.MiddleCenter);
                    //e.g. merge cells in the the very last row
                    //CellRange trg = new CellRange(nmRows - 1, 0, nmRows - 1, 3);
                    //oTable.MergeCells(trg);
                    //oTable.SetTextString(nmRows - 1, 0, "Merged cells are goes here");
                    oTable.SuppressRegenerateTable(false);
                    btr.AppendEntity(oTable);
                    tr.AddNewlyCreatedDBObject(oTable, true);
                    ed.Regen();
                    oTable.Dispose();
                    bt.Dispose();
                    btr.Dispose();
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
        /// <summary>
        /// </summary>
        /// <param name="poly"></param>
        /// <param name="prec"></param>
        /// <returns></returns>
        public static List<string[]> PointsToTable(Polyline poly, int prec)
            List<string[]> points = new List<string[]>();
            for (int i = 0; i < poly.NumberOfVertices; i++)
                SegmentType stype = poly.GetSegmentType(i);
                if (stype == SegmentType.Line)
                    LineSegment3d seg = poly.GetLineSegmentAt(i);
                    if (i == 0)
                        Point3d p = seg.StartPoint;
                        string[] ptitem = new string[5];
                        ptitem[0] = (i + 1).ToString();
                        ptitem[1] = string.Format("{0:f" + prec + "}", p.X);
                        ptitem[2] = string.Format("{0:f" + prec + "}", p.Y);
                        ptitem[3] = string.Format("{0:f" + prec + "}", p.Z);
                        ptitem[4] = "";
                        points.Add(ptitem);
                        p = seg.EndPoint;
                        ptitem[0] = (i + 2).ToString();
                        ptitem[4] = "";
                        points.Add(ptitem);
                    else
                        Point3d p = seg.EndPoint;
                        ptitem[4] = "";
                        points.Add(ptitem);
                else
                    if (stype == SegmentType.Arc)
                        CircularArc3d circ = poly.GetArcSegmentAt(i);
                        if (i == 0)
                            Point3d p = circ.StartPoint;
                            ptitem[4] = "";
                            points.Add(ptitem);
                            double rad = circ.Radius;
                            Point3d cp = circ.Center;
                            ptitem[0] = "Center";
                            ptitem[1] = string.Format("{0:f" + prec + "}", cp.X);
                            ptitem[2] = string.Format("{0:f" + prec + "}", cp.Y);
                            ptitem[3] = string.Format("{0:f" + prec + "}", cp.Z);
                            ptitem[4] = string.Format("{0:f" + prec + "}", rad);
                            points.Add(ptitem);
                            p = circ.EndPoint;
                            ptitem[4] = "";
                            points.Add(ptitem);
                        else
                            points.Add(ptitem);
                            Point3d p = circ.EndPoint;
                            ptitem[4] = "";
                            points.Add(ptitem);
            return points;
        /// <summary>
        /// </summary>
        /// <param name="oTable"></param>
        /// <param name="row"></param>
        /// <param name="column"></param>
        /// <param name="value"></param>
        /// <param name="height"></param>
        /// <param name="cellalign"></param>
        public static void SetCell(Table oTable, int row, int column, string value,
           double height, CellAlignment cellalign)
            oTable.SetTextString(row, column, value);
            oTable.SetTextHeight(row, column, height);
            oTable.SetAlignment(row, column, cellalign);
